greenbank
I hope this is the right section for this thread. I'm sure someone will let me know if it isn't.
For five years we've lived in rentals with either no garage or damp carports. I've had no workshop and have stashed my cars and bikes all over the place.
That's been rectified.
The shop on the property we bought isn't the design I would have built, perhaps, but it's more than fine and I feel fortunate. I'm going to include far too many diagrams below.
It's a metal pole building, 36 ' x 48', set up as a four-car garage with 36' deep stalls. For the small cars I enjoy tinkering with, this means I can double them into each stall. The building is divided into two 24' x 36' spaces. I am planning on using one side for car storage and the other as my workshop, with the current project and probably my usual "daily" car on that side.
I hope to eventually add a carport to the side with the windows as storage for my old truck and car trailer, but there is the mother of all stumps to get rid of first, and it's not top priority at the moment.
I'll ask my questions below the images. I have a couple of practical questions and would also solicit feedback on how you personally might set up your workspace in the workshop side. I can't promise to use your ideas but it's always nice to hear how others would do things.
We just moved, so the building is currently holding cars on the shop side and endless cardboard and junk ("why did we move this? And this? And this? A dumpster would have been a better idea."). The one day the shop was empty I was so rushed I only grabbed a couple of crappy snaps.
Outside (well, duh!).
Inside, this is looking at the "shop" side. It shows the batting and a bit of the truss and cross-ties. The center wall is load bearing.
Now for some sketchup renderings. Below these is the floor plan.
Here is the actual vertical layout including the trusses and ties:
A hoist will fit, where to put it is undecided:
Finally, here's the floor plan:
There is a wood stove in there now, but, frankly, I hate wood stoves for shop heat. Everything I own leaks gasoline at one time or another, and we frequently have burn bans here, not to mention it takes up a lot of floor space and I find that there is generally a 10' radius around the stove where doing any sort of work is unbearable. Plus it is definitely not to code. So it's coming out.
Practical questions:
Planning Questions:
Anyway, I'd love to hear what you think I need to consider, what layout ideas you might have (even in the most general terms) and anything else I should think about. I'll post photos here when we start on the insulation and drywall, hopefully in a couple of weeks.
The shop on the property we bought isn't the design I would have built, perhaps, but it's more than fine and I feel fortunate. I'm going to include far too many diagrams below.It's a metal pole building, 36 ' x 48', set up as a four-car garage with 36' deep stalls. For the small cars I enjoy tinkering with, this means I can double them into each stall. The building is divided into two 24' x 36' spaces. I am planning on using one side for car storage and the other as my workshop, with the current project and probably my usual "daily" car on that side.
- On the shop side of the building, I plan on insulating and drywalling. Furring out the walls and putting in batt insulation is a no brainer. But on the ceiling, I assuming I should leave the fabric batting in place, furr down, and place regular insulation below it...but leave an air gap between the two? Does the roof need to be ventilated, then? A pointer to a good online resource would be great.
- I was planning on leaving the storage side with just the standard batting in place, as I don't plan on heating it...money is a bit tight for this initial "prep the space" project. Is this a mistake? Should I insulate and drywall the entire building?
- The shop's juice comes from the house, and is only 60 amps total. This feels pretty light to me. I was going to see about bringing in a dedicated 200 amp service from the street, which is probably overkill. Realistically, most of the time I will be running a compressor and a parts washer. I don't weld (though it's on my list of things to learn). I do have drill presses, etc. I also want to heat with 220 low-temp ceiling-mounted heaters. It's pretty mild here and I have no problem wearing a sweat shirt. I like 60 degrees as a working temperature.
- Should I plan on air in the walls, or is it best of maintenance to just surface mount it? Obviously, I'll be thinking about and putting additional electrical where warranted. There are lots of outlets but only one 220, not surprising given the amount of juice.
Planning Questions:
- A hoist will fit. I like two-post hoists. The ties are about 15' apart, so if I center a hoist the type of cars I typically work on fit between them. They're nine feet from the floor, and I'm just over 6', so I typically raise a car about 6 and a half feet of clear space underneath. However, I'd like to be able to service my wife's outback wagon, and ideally my old '68 F250, which is more problematic. I will consult with an engineer to see if I can move the ties slightly further apart on the hoist side.
- I was thinking of putting the compressor on the storage side of the building, right next to the wall dividing the spaces. I can run as much pipe as I want along the wall and back on the other side to give a good 50 to 75' run before it gets to the first machine. I run a bead blast cabinet and hand-held air tools. Doubtful I will be painting, a good friend down the road has a spray booth I can use if he's between projects.
- I would like to keep the ability to park my "often used" old car on the non-hoist side of the shop, being able to move it out if I really need the extra space. But other items I have: Blasting cabinet, parts washer, grinder set up as a buffer, drill press, 20-ton press, toolboxes, flammable storage cabinet. I would also want some shelving on this side to hold some of the pieces of my current project that I'm working on. I would like to eventually consider a lathe. My initial thoughts are to use the wall space, obviously, but to concentrate the big stationary tools at the bathroom end of the shop.
