how about this pisser
fury9
Mchenry, IlLaHnoYs
Thinking about just putting a tube on the biggest (c'mon within reason)funnel I can find and mounting it to the wall with the tube going outside. I pee alot
GGB
It wouldn't be the first time that design has been used....
GGB
machine_punk
Napa Valley, California
The problem with this is the smell..we learned quickly in the military to use the bathroom a little bit away from our vehicles...it didn't take long to get smelly.
Slick111
Everett Wa
Do you drink a lot of beer ? I do so I built a bathroom in my garage best thing ever you wont regret it.
geologist
When I finally get around to building a new shop, I'm going to build a replica TARDIS in one of the corners to use as a bathroom.
Bookworm
Where the wind comes sweeping down the plain
Did this back in the 80's at a friends place. We dug a hole right behind the shop, filled it with gravel. Ran a hose from the funnel to the hole, covered it with dirt. worked great. We drank alot of beer back then, and used the funnel regularly. Never smelled bad, never a problem.
jhelrey
MN
The object you want to make is also known as a beer bong even though you will be drilling a hole and feeding it to the outside. Just don't drink the other end anymore.
sberry
Brethren, Michigan
I have a separate drain, have running water though and on occasion bleach it.
