Mmfh
MEMBER EMERITUS
Hey there,
Big Maxx 75k Propane unit. Seems to me the control of the propane pressure is done inside the gas valve, is that right or does it need a regulator like the ones you see on the 20 lb tanks? It has a Honeywell VR 8205m.
I got this heater from a buddy, and he had a regulator at the tank bringing down the pressure before it got to the heater. Seems like that is double regulating and probably won't hurt but seems unnecessary.
Maybe its safer to run low pressure up to the heater, than to run high pressure and regulate it down at the heater. Can't find anything in the manual about using a regulator. Its says use a valve and a drip leg and that's it.
He also had a One way valve in the line before the propane reached the heater. Is there any reason to use a one way valve and a shut off valve??
I've installed this in my shop, and would like to clean up any unnecessary items in the supply line before I call this install done.
Regulator needed?
One way valve needed?
What do you think?
Thanks
Mm
Regulator needed?
What do you think?
Thanks
Mm
