OLD BARNS...anyone else have one?
just1more
We have a couple of older barns on our property. I started to restore one of them four or five years ago. We did get a new roof on it, and I have one of the walls rebuilt, then the economy took a dive and it has been setting since.
I am hoping to get started on it again this summer.
Here is a pic that happens to have both barns in the background. The gambrel roof barn is the one we are working on. This pic was taken before the roof was on... ....Does anyone else have any old barns/ farm buildings they either have/or hope to, restore??
cyamaha2007
St.Charles MO
I have a old 40x60 pole barn Its build like a tank all the girts/purlins are 2x12 oak way overkill. My new barn has 2x4 every where this one has the 2x12s. Id like to save it but rot has got the better of the telephone poles supporting it. The rest of the barn is good but the posts, i cant see a good way to save it yet, they are rotted about 2ft up from the ground. I think i may take it apart and build a new barn with the wood with new posts.
J
just1more
I was originally hoping to use the barn for my shop to work on vehicles, but it would have taken way too much to make it work. The ceiling is less than 8 foot high and it has cow stanchions so the concrete is not even.
We are planning to keep about 1/3 of the front, lower interior original looking and build a wall. The back 2/3 will be used for storage area for a couple of my boats, lawn equipment, bikes, a small wood shop, etc. The hay mow above the back 2/3 will be kept and used for a large "social area". I'm hoping to remove the mow above the front 1/3, so it would be open to the ceiling. This would make the mow overlook the front area, kind of a balcony look.
letz4wheel
Southern Indiana
Just this one...it is enough!
RPH
Michigan Thumb
Yup, got one that's about 100 years old, 32x50'. That's the best guess by the old folks here. Mortise and tenion joints with wood dowel pins hold it together. Good old building that will be used for wood shop. Putting up new 30x72' for the cars. Love the old ones seen a few on cl free for the tear down. What a shame.
raggmann
Botha,Alberta,Canada
I've got one.
I've been told it's approx 100 years old as well. The old red Jeep pictured is tore apart and stored in there awaiting time for me to get busy restoring it.
Bull
I have an old barn that my grampa built from recycled lumber. I have thread about it on here. No post and beam construction, no fancy mortise and tenon joints, just stick framed and basic. I love old barns.
Do you have pics or details about what you did to the one wall that you restored?
ihredo4
100 miles W of Daileyville in Idiotnois
jlckmj that would be a dream to me. Thats what I wanted to build my house in but now due to being disabled that doesn't look to happen. And you are so close. DAMN
On my parents property they have a barn that his grandfather built. I hope to retrofit that and turn it into my shop. Basically a 20 x 30 with two milking areas with gutters. Have to replace all cement and raise the loft. fun fun fun
J
just1more
sorry no pics.. I have completely replaced the front (south)wall below the hay mow. Before I could do any wall work,I pulled the barn back into plumb. It was leaning over 10". To do this, I bolted a steel beam at the height of the mow's floor joist on the east wall, letting it protrude past the front of the wall a foot or so and hooked a chain onto that. . I used my old backhoe to pull on the chain. I got about half of it out before running out of @ss with the tractor...it just wasnt heavy enough and would spin out.
Then I dug a trench about a foot deep against the foundation of the west wall. I placed another steel beam in the trench and staked it. Next I connected a pair of chains from the upper east wall beam to the lower west wall beam. Using a port-a-power and chain binders, I finished pulling her back into plumb, fractions of an inch at a time. (I had to use two chains so I could "rebite" the porta-power" and not loose what I had just pulled.)
Once I had it pulled back to plumb, I used some old screw jacks to support the main beams carrying the mow floor, about 2 feet inside the old front wall. Once this was done, I removed the front lower wall. I then installed a new 2x6 treated bottm plate and used 2x6 studs, place on 2 foot centers to build the new wall. After the wall was framed, I sheeted both the outside and insdie with 7/16" OSB.
Finally, I removed the chains that had been holding it plumb and the jacks that had been supporting the mow floor. AND it STAYED!!! now I am saving up to buy steel siding..
I will try to do better about taking pics when I rebuild the remaining 3 walls.
btw... some great pics!!! keep em coming!! (did you know I can not find a good barn forum?)
KCarGuy
50 miles outside Chicago, illinois
I Love old Barns.
My Great Grandmother had a Cool Old Barn in Downstate Illinois.
And My Aunt and Uncle bought a Big Chunk of Property in Wisconsin that had only the stone Foundation left from the original Barn, and I helped rebuild that Barn over the course of a Summer back in 1971. Great Times.
Its so sad that most are rotting away and being replaced with Metal Buildings. I have actually thought of just driving around several States and just taking photos of these old barns before they are all gone.
Hell I have 6 weeks of vacation each year.
beerdog
Buffalo Grove, IL
Can old barns like these bu upgraded to be more than just an old barn? Upgrading being adding wall sheathing, drywall, insulation, etc. Or is there simply too much involved.
J
just1more
A lot has to do with the foundations and how solid they are. I design kitchen cabinetry and have done 3 or 4 kitchens in barns that were converted to homes through out the years. I would LOVE to find one good enought to convert!
A contactor friend of mine would get all the "take out" stuff (doors, wiindows, even an old metal spiral stairway) from house remodels and use them his "party barn". It was nice enough they used it for his parents 50th wedding anniverasary!
J
just1more
stingry,
That was a beautiful barn.. didnt have a lot of time before to ask... do you know what caused the fire? Insurance come thru?
J
just1more
Well, over two years have passed since starting the barn thread. Thanks to mother nature, I am working on it again. A couple of months ago, a storm blew about a third of the back wall out of it. This let the leaning barn, lean even more. The back wall was about a foot out of plumb. Here are a few pics taken this weekend..
This is what the barn looks like... front wall was rebuilt a few year ago..
This pic shows the back of the barn with the right portion of the wall missing.. Notice how much the right hay mow support post is leaning..
Here is the back left corner.... with the barn leaning so much, it broke one of the 2x6 studs (They were on FOUR FOOT centers! It's a wonder it was even standing!!
This picture shows the back with the lower wood siding removed...
Getting better! After pulling it back into plumb, We built 8 feet of the side wall where the stud was cracked. Now the 2x6 studs are on two foot centers!
8 feet of wall built, 148 feet more to go...
Diesel Dan
TN
Unless you have animals the old cow barns are about useless, IMO.
We had one and it was built in the '40/50s and a barn buyer didn't even want it. Probably 75' long, 30' wide. 7' max on the bottom with a 20' tall open haymow. Would have been $20K+ to roof it, then the stem walls were squatting out, bad side boards etc. Glad I was able to leave that behind before having to address it.
The "machinery" style barns with more open floor plans are much more useful however.
J
just1more
Diesel Dan,
Nope, no animals....
I agree , restoring an old barn is not for everyone. I am fortunate in the fact I actually have two barns on the property. The other is an open "machinery barn" in which I keep my old backhoe, a junk bucket truck and various "future projects" and their parts I just couldnt live without...LOL....
I also have an old corn crib that generally houses my 97 one ton Chevy plow truck and doubles as a general purpose paint booth. The old overhead grain bins have been converted to storage with metal grocery store shelving.
There is my 4 stall heated shop that I actually do most of my work in. And a couple other smaller storage garages/buildings.
So, this barn is partially a "labor of love". I plan to build an interior wall across the front 1/3 and keep most of it as it was when built in the 1920's, including the cow stanchions. (Do you know how many people under 30 dont know what the stanchions even are/ or how they were used?) We use this part when we have hay rack rides, parties, etc. as a place to set up and serve food drinks, etc.
The hay mow will have a stairway installed so most of us old people can get up there and will be a continuation of the eating/party area. (again, under 30's wonder how you get those big round bales up there) I suppose we could try using the old hay forks and track that are still there. (I wonder how many "miles" I put on the ol' 8N pulling that cable)?
The back 2/3 is/will be used to keep my firewood dry, a shop for my stationary woodworking tools, storage for the riding mowers, tillers, misc. garden tools, even an old boat or two, etc.
I'm guessing I will have somewhere in the neighborhood of 25G in the restoration (and a heck of a lot of backbreaking labor). I know guys that spent that to have a 3 stall garage built. So, I actually think this is a great deal.
Plus "preserving a small piece of the rural landscape", as they say, ....Priceless.....:)
HAY YOU
Still working on our 101 year old barn after a delay of 3 years because a highway was going to come thru are property, changed to another route so work has started again.
Tarnished
SW Ohio
Thought I would post a couple pics of my "Old Barn's" in SW Ohio.
I have been the caretaker of these old barns for about 20 years now, and other than needing a new coat of paint, they are in pretty good shape. Their feet are out of the mud, and they have new tin over their heads. :thumbup:
The longest is an old tobacco barn. About 30' wide by 75' long. Not sure when this barn was built and think this barn may have been moved to this location. There are signs that it was taken down and rebuilt at some point, but no one left old enough to tell me for sure.
The second and smaller barn was used as a sheep shed when I bought the place. I believe this may have been the original barn for the place. This would make it around 130 yr old. The main part to the right is 30'wide & 30' long. An addition was added to the east end at some point and used for hogs. This addition is about 24' wide & 24' long.
The main part of this barn was completely rebuilt in 2001, and now serves as my main shop area.
I love these old structures and have tried to keep mine as original as possible while still maintaining a usable structure. I hope it will outlast me at any rate.
More pictures here: Sheep Shed Shop
Lippyp
Shropshire, UK
I have a small pole barn down the end of the garden built by a previous owner, its not immensley old and by the time we moved in two thirds of it had collapsed but I'm slowly putting it back up, we half half of it saved, the mowers etc live in it at the moment but the plan is for that bit to become my forge when I finish rebuilding the middle bit and the mowers will move in there. It uses railway sleepers (railroad ties) as posts! The outside is rather rusty corrugated tin.
You cna see it here: http://www.garagejournal.com/forum/showthread.php?t=152853&highlight=Barn
My garage is also an old cowshed, over 100 years old.
mooseracing
Surprised I didn't post any shots, I have a few on my phone, but this one seems to be the widest out.
I run my store out of this side of mine. I added another 12x20 section about 2yrs ago to fit more equipment. Planning on going across like that as well. Its been a PITA, but alot of people like seeing the hand hewn beams when they come in.
J
just1more
Wow! Glad to wake up this old thread! Great to see all the other barns out there! Nice to know I'm not the only old barn junkie...
:beer:
J
just1more
Can you guys include interior pic's if possible? Like an old car, they have character.
I dont have any really good interior pics, but took a few "before" pics of the damaged areas..
This is a pic inside of the lower area. The right wall has been replaced with the new wall shown in previous pictures. You can see how it was bowing out from the broken stud. The back wall also shows how badly it was leaning. The original cow stanchions are on the left. The scatterd pipe fittngs used to be neatly packed in boxes.
This is the same corner in the hay mow. Seeing the rotted floor boards, it's obvious the roof had been leaking for many years.
Not the best picture, but it shows the free spanning roof system. Quite an accomplishment back in the 20's..
J
just1more
Hay You, great pics! Any idea how old your barn is? Looks similar in age to ours..
raggmann
I have an old hip roof barn and am trying to figure out a way to take the roof off. Can't afford a crew or a crane. Any ideas?
It needs new shingles but I'd rather just lift the roof off, put trusses on, and turn it into another garage as I don't use the loft area.
Best pics I have of the barn
I replaced the old yellow garage with this in '11. Built it myself with maybe 2hrs help and no blueprints. 24'X24', 10' cielings & 10' wide lean to's.
Lippyp
Shropshire, UK
A friend of ours in France has the most amazing barn, the roof is like a cathedral roof, partly built into a hillside with a ramp up to the first floor downstairs was cow stalls and still has names and dates chalked on the beams from when it last housed cattle. Some of the timbers are 18"+ square. Outside walls are stone as are the roof tiles. I'll see if I can take some pictures when we're next over. Id guess it dates back a good couple of hundred years.
STINEY
Bucyrus Ohio
I love seeing all these barns getting well-deserved attention.
Little update on one of mine....
Front before. New gutters/downspouts were done a couple of weeks before.
Front with roof painted.
Front view with one side done.
A view from the other end.
Before. (again, after gutters/downspouts)
Roof painted. The old boarded-over door is also being blocked up here. Making the foundation all one height, I don't need or want that door. The blocks are filled, and prior to that, bar was drilled into the concrete threshold. Its essentially a solid foundation wall now.
End wall of the "Straw-shed" part of the barn. This end had lots of openings to allow for filling all the way to the top with straw or hay.
Inside of same wall. That weird large truss thing will soon be history too, it was apparently built to allow the ground level to be free-spanned, but was causing the wall to bow out from the load. Bad design, but interesting idea. We added posts back in at ground level after jacking the beams up 4". The weird truss thing will be removed when I get around to it - maybe a basketball court in the near future?
You can see one of the new posts in this picture, and some of the cabling I added to pull the wall back in with come-alongs. Worked well as a temporary fix, moved the wall back in over 6" that way. It had moved enough to start dropping floor joists, that's when I noticed the problem!
Lots better.
Other side.
Has a "rubrail" so it does not ding the siding up when opening it. (That's the white horizontal piece)
Inside of sliding door. Someday when/if I pour concrete back here I can bring it right up to the new door and darn near have a weather-tight seal.
Three openings are all framed up for overhead doors as well.
Stuck up sections of the old doors, they stopped some of the weather until the overhead doors show up.
Lots of progress on the front.
Finished end wall of hay shed back section of barn.
Nearly finished other end wall. Some trim and soffits left.
The small single overhead opening is all framed now. Finish siding and some more trim, then doors. The small opening, we reverse calculated in order to get the door & track as close as possible to the overhead beams, then measure downwards in order to raise the threshold as far as possible. This is as good as it gets, I had planned on a small retaining wall and 2 levels on the front, now I know exactly where they have to go.
All trimmed up.
Front is done. Just waiting for doors now, those are the old sliders just screwed to the inside to block the opening temporarily, I was limited to just using the man-door.
Finished! (Is there ever really such a thing as finished?)
Need to dig out and pour a threshhold here. I intentionally waited until the door was in (we crammed it UP as far as possible, let the bottom fall where it will as long as it is UP as close to the ceiling beams as it can go). Am planning on a 10' apron as well. Have to get creative where the outside elevations change from the big doors to the little one, no getting around that.
J
just1more
You have any pictures of your building? Sounds like the only way to remove this roof would be good old manual labor. :sad:
GCncsuHD
Salisbury, NC
OP, I know this thread is old, but love the 67 and the 71/72, and the barn of course. That 67 looks identical to mine.
This barn isn't too old, maybe 20 years; used to house our horses before we got rid of them, but it does have some old iron inside along with my 67 twin to yours.
This the barn on my property, it's been through several generations of my family, I hope to fix it up soon. Still use it periodically for nursing calves. Structurally sound, but the siding is all rotten. Unfortunately all of my pictures of it are behind my truck.
DSC09882 by wrfalcon75, on Flickr
This picture you can kinda see the smaller barn, next to that is the corn crib and another couple small pole barns.
DSC09880 by wrfalcon75, on Flickr
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Stiney......great save, and a super nice straight barn. The restoration and saving of the barn looks great.
Where's Reiferman? I would have bet money he would have been in on this thread. His is another super restoration/save on an old barn, both inside and out.
