Hi All-
I'm trying to run a new device in my garage and I'm either not getting power to the outlet or I'm getting the wrong voltage and need to know how to correct it.
Here is the device input power label. From this I think it can use either 208v or 230v:
Here is the outlet I am connecting to:
Here is the electrical box layout in the garage that the outlet is powered off of:
And here is an upclose of the 2 breakers that I circled in red in the picture above that the outlet is connected to:
Questions:
(1) Can I stick a volt meter on the outlets BLACK and RED wires and I should be able to measure the voltage coming out right?
(2) What is my electrical currently setup for -- and how do I fix it if it's not the correct voltage for what the device needs?
I am assuming the device (welder) is good, as it's brand new out-of-the box. I guess there is a slim chance it could be bad, but I'm guessing my problem probably lies with the electrical?
I'm going to post this on another board as well so I can try to get this figured out as quickly as possible.
Thanks for any help! When it comes to electrical my brain short circuits!!!
-Brian
Questions:
-Brian
