Geez, another senior moment.......
Or it's the morning after the night before... I haven't done that in ages, but still remember what it's like...
I throw all the parts I take off in a cardboard box, but that's about it. Somehow the ratchet/socket/extension I need always ends up on the complete opposite side of the car 100% of the time
Nothing fancy but works nicely.
Nice!
You might consider button head screws with jam nuts on the bottom to keep the inside a bit "cleaner"
I had originally installed the first castor with the bolts the opposite way but the nuts interfered with the castor pivoting.
Organization..
That was why I suggested jam nuts. They are about 1/3 thinner...
Jam nuts are for locking a threaded (whatever) onto what it is screwed into. Example: Spherical rod ends into a control rod. It threads on and can be adjusted for length, then you need to lock it down. The jam nut does that and takes less space.
You should be able to find then at any decent hardware store.
Nice tray. I'm just wondering, since it's metal, why not just use JB weld?
Got to agree ! Creeper wheels get caught in expansion joints/cracks.This, and lay down some large cardboard for you to slide in and out on, this is actually easier at times than a creeper...
After a few day's pounding on it and a few other projects.
View media item 23512
A stub welded to the bottom that wasn't big enough so I cheated.
View media item 23509
And a couple of it hanging around.
View media item 23510
View media item 23511
Still have a few holes to fill but that's always a good thing![]()
EDIT just noticed the "Hand hold" in the top! Never mind...
Thanks!
The handle was nearly forgotten as you noticed! Glad it gave you an Idea, and post a picture if you think of it....
I used to use the baby wipe containers. Even before the kids got too big for them, Costco changed their packaging and you only got one container and a bunch of plastic-wrapped refills instead of individual tubs. I was bummed.
P.S. I use the tubs from frozen entrees (like Stoeffer's) for small parts. Back when I was a bachelor, I had a steady supply. Now that I'm married, they are much less common.
