Reparing a makita drill
junkyardjeff
Dayton Ohio
I have a 15 year old 7.2 volt drill that looks like is going to need a new trigger switch,are these things repairable and parts available or is it like most modern **** that is a throw away.
J
junkyardjeff
Dayton Ohio
Dont have the model number handy and is a variable speed,doubt the model number can be read as I think its on a sticker and they cant be read any more.
Justin1776
SW Florida
A 6172D switch is $40, at that point it's probably not worth it considering you can get many 12 volt and 18 volt drills for around $100, with two new batteries and a warranty. I've got an old 9.6 makita but it just sits because the batteries are so expensive (mine are junk) and the drill is very big for it's power output.
Justin1776
SW Florida
NinetyTwoFifty, do you have a old Makita drill interest? For some reason I can't see myself parting with my 9.6 makita even though it is junk compared to my 18volt LXT's. I have old memories of my dad using one when I was a kid in the early 90's when they where THE cordless drill to have.
Winchestertonfieldville, Ga
Well, kinda. I have bought 5 used Makita drills in the past year or so though....
J
junkyardjeff
Dayton Ohio
I bought it new and has served me well through out the years so I would like to keep it going,I like it much better then the new Makita I bought last year. I used this one for work and when the batteries got too expensive I got a deal on the new drill set and took it home to use in the garage,I eventually bought one new battery so to get my moneys worth out of the battery I will have to fix the drill. I had battery issues with the new drill and had them replaced but the new drill does not last as long on a charge like the old drill.
Provincial
Near Salem, OR
junkyardjeff, I have a variable-speed Makita 7.2V drill that you can have for postage. It worked great the last time the battery charged, which was ten years ago. I also have a single-speed version and two flashlights, one of which is a floodlight (trouble light). I have some batterys that won't hold a charge. PM me for details. Should fit in a medium flat rate box. I have a steel box and a plastic box, too.
Ben Buck
S. W. Ohio
:beer: JunkyardJeff, try M&R Electric over on Fifth St, not to far down from the main US postal mule station. I bought a switch for a Makita 9207spc polisher for $20.00 there last year. It's a good place to deal with, they repair a lot of tools. 1516 E. Fifth St. 222-6282. :beer:
J
junkyardjeff
Dayton Ohio
I forgot all about them and will give them a try this week.
glenmore
Los Angeles
Unless you absoulutely need this specific driver for work, I'd skip the repair. These are relatively common items at garage sales I go to and can be bought for less than the part price. The 7.2v IIRC does not have a clutch like in the 9.6v and modern drivers. The clutch is absolutely a big benefit with this type of tool.
