Insulated Tools - Any use?
Any insulated in your box?
  • Yes - I have some
    Votes: 19 61.3%
  • Nope
    Votes: 12 38.7%
  • Total voters
    31
sjotis
Do you guys have any insulated tools in your box? What did you buy them for?
ToolmanTom
Utah
Not those particularly but, I do have some. I work on live circuits, I need to adjust metal screws while monitoring the oscilloscope. If the tool was not insulated it would throw the readings way off.
kbs2244
Not much for car stuff, but for sure in my electrical tool pouch.
I had 4 inchs of screwdriver shaft vaporize on me when I touched the edge of the box I was working in while tightening down a lug.
It was supposed to be a dead circuit, but you never know.
All those screwdriver shafts are rubber coated except fot the last inch at the tip.
Same fot the pliers. Just like your pic.
LoneGunman
The Gunshine state
"It was supposed to be a dead circuit, but you never know."
Famous last words of a whole bunch of people. I'm sure youve heard it before but ALWAYS check a "dead circuit". The proper way to check a dead circuit is to check your meter on a known live circuit first, check the circuit you are working on to verify it is not energized then check the meter again on the known live circuit. Also don't forget to lock out and tag whatevers feeding that circuit.
If your screwdriver vaporized you were obviouslt not working on a 120/240 volt system, you are lucky the arc flash didn't get you.
sjotis
I had heard hybrids might require insulated tools, but I'm not sure that is true. Any automotive uses for these?
Merkava_4
Clovis, CA.
If your screwdriver vaporized you were obviously not working on a 120/240 volt system, you are lucky the arc flash didn't get you.
I unplugged a welding machine at Fresno City College one day. The plug had an internal short and a white flash shot out about 3 feet when I unplugged it. The plug receptacle was powered up with 480V 3-phase. It knocked the power out on the whole entire campus for 5 hours. :D
MarkH
Kansas
With building maintenance as well as machine repair we have a few at each location. A couple screwdrivers and a plier for those times they are needed. Again not common use but nice when you need them.
kbs2244
Yeah wakeboarder, it was only 120VAC, but it was upstream of the CB.
I have no idea what the amperage was.
It did take a while for my eyebrows to grow back.
wakeboarder311
vermilion ohio
what people dont understand it may be only lets say a 20 amp circuit breaker but its the fault current availible. it could be anywhere from 10k up to 65k
LoneGunman
The Gunshine state
you can vaporize a screwdriver on a 120 volt circuit i can speak from first hand experience:shocking:. i only beleive in Klien
I guess it's semantics, I'd considered "vaporized" as nothing left as in an arc flash on a higher voltage system. I have never heard of an arc flash on a 120/240 volt system, then again whats the appropriate definition of "arc flash"?
I use to only believe in Klein Tools until I bought some of the German tools like Wiha, Wera and knipex, no more Klein for me.
*edit, learn something new everyday, just read an article by Holt about arc flashes on 120/240 systems.
wilbilt
NorCal
It's like .007 amps that can kill.
I have a few insulated drivers. These schools were built in the 1940s and have had several "improvements" since then.
ImportTuner
You're lucky to be alive to talk about it ... :)
64merc
Texas
In my electrical bag I keep an insulated screwdriver (1000v) that you can change out the different bits on. You know, just a plain ol' multi screwdriver except that it is made out of some kind of plastic composite. Of all places, I got it at Wally World for like $3 or something. I don't work on live circuits so this suits my needs fine.
eschoendorff
Especially since Klein screwdrivers are just basically pratt-reed screwdrivers anyway...
http://www.pratt-read.com/modules.php?name=Content&pa=showpage&pid=4&cid=4
Uncle Buck
Kansas
You just explained a whole lot there bub! :shocking:
BrianAltenhofel
In a trailer somewhere in the country
All the circuits in my trailer house are breakered on the neutral leg. It was NOT a fun experience to think that the circuit was dead and find it hot when you hooked up the ground wire (the previous fan went hot-neutral with no ground and the ground wire to it was just capped).
I'm waiting to replace the box because I need a new panel to send 220 to the garage. Federal Pacific breakers are way too expensive ($70 at HD last time I looked) and I don't like that the kitchen outlets (including fridge) and swimming pool pump are all running off the same 15 amp breaker. Right now, the front porch, back porch, cellar, and garage are on a single 20 amp breaker. Trust me, that has been real fun with a deep freeze, welder, beer fridge, and various other power tools.
(Hey, at least the trailer was old enough and the pool has about foot above ground so that we only paid for the land it sits on...)
Rrumbler
Las Vegas, Nevada
I have had insulated Klein drivers in my box and belt since the early sixties, still use some of the originals, but they are a bit long in the tooth, and have a lot of battle scars. I would never depend on an insulated driver, regardless of the rating, for shock protection, but always considered them a godsend when working in close, congested panels, or terminal blocs and switch sets. They may have saved me a burn or flash, or two, fer-sure.
