How do you bend 1" pipe?
bad_idea
Pasquotank, NC
With a bender of course..... Figured I would get that out of the way for all you smart asses out there. I enjoyed building an end table for the wife and now I want to build a set of patio furniture for her. I am in the planning stages now. I have a basic set of metal fab tools at home (hobart handler 187, chop saw, oxy/act, 4 1/2" grinder) and access to a well equipped fab shop at work. I would like to build a jig on my weld table to bend some 1" pipe around for the chair backs, a jig for repeatability (planning on 6 chairs). I am concerned about the pipe flattening and am not sure how to prevent this. I would like to keep this fairly simple but if I need to buy a couple tools for this, no harm. Below is a pic of the end table I made (just to show I am fairly capable with steel) and a pic of a chair I am looking at for design ideas.
hunter1151
Kansas
Well the way we used to do it with out a bender is to fill the "pipe" with dry sand and bend away.
KPSquared
Wetaskiwin, Alberta, Canada
Get a rose bud tip for your torch. Heat it up until the whole section is glowing, then bend away. I've bent like this without a bender. Just clamp something round down to the table that's the right radius and make the pipe follow it.
Ign
Butte Peak ND
1" pipe as in 1.315 OD? It's pretty substantial, you obviously won't see the radii in your table legs (nice work BTW). I've got a 1" pipe die for my JD2 and have built a lot of non-structural stuff with it. Easiest to find is of course sch40, and it's not cheesey like conduit. There is of course sch5 and 10 in theory, but hard to find - at least for me.
Oh, love the perforated sheet on your chair. That stuff is SPENDY!!
Handrail from 1" pipe w wall returns
bauschracing
Springville Alabama
There is a site called gotrikes that has plans for a hyd. tubing bender that are easy to go by and are under $20 and is down loaded from an e mail. They use the PRO_TOOLS dies, and a harbour freight hyd. ram (under $100). PRO_TOOLS has a lot of dies from 1/2inch to 2 inch and round or square. If you can weld, cut and drill, it is an easy project.
PRO_TOOLS also has a web site and has a bender similiar to the JD2 but built heavier. It is on sale for $199. My racing partner was in the Tampa area and dropped in their store. He was looking at the JD2 and found that they had one in display for compairing the two side by side. He bought the PRO_TOOL bender on the spot, and I bought some dies and he picked them up saving me freight.
Just something to look at.
Mike
Here is a picture of the GOTRIKES bender
CarterKraft
DFW
The HF kinker does a fine job on pipe, you will have allot of waste though on small leg pieces like in your examples.
