binder man
I'm about to put up a 60x40 (may be subject to change). What is the best design you guys have seen as far as location of doors and office and such? My original thought was one door in the middle of the narrow end with the lifts angling off on both sides if need be. But what I ran into there is I do semi work along with pickup/automobile work. So when I pulled a semi in it would block alot of the bays.
My next thought is very close to the above. One door offset to the right side of the narrow end. The office and main walk in door on the left side. In the back of the office/ reception area would be a clean room sectioned off from the office for engine/transmission work. This seems the best to me as that area would be almost impossible to get a truck into anyway. There will be a door going from the office into work area. This way I could still angle the bays in with one or two 2 posts and a 4 post (eventually) and still be able to pull a semi all the way in and get vehicles out.
The next idea I have is almost identical as above with the exception of your door being in the back with the office on the other opposite corner. Once again you could pull a semi up to the front wall and the office would block the one side leaving room for your lift bays behind to easily maneuver a vehicle in or out.
So what are your guys thoughts on the best layout for a working shop?
