HELP: 30 Gallon Kobalt Air Compressor not starting
tonyvlx
Toronto
My 30 gallon Kobalt air compressor will not turn on. I hear the motor make noise but the belt and pully wont rotate. I tried to turn the pully by hand(piston) and it takes lots of force to slightly move the pully. Is the motor seized?? Its a 120Volt 15 amp motor and keeps tripping the breaker. any help would be appreciated. thanks
trboxman
North Bend, WA
The unloader my not be working so it's trying to start under pressure. As was suggested earlier, take the belt off and see whether it's the motor or the pump that's hard to turn.
T
tonyvlx
Toronto
took the belt off and the motor is seized. can these motors be rebuilt??? if so what the average cost to rebuild?? thanks
Steevo
43.49600, -112.04300
The motor that comes with that compressor is a throw-away. You'd be money ahead to buy a new replacement in a quality brand of equal HP / RPM and call it good.
Dale B
Rowland Hts , SoCal
Might be a real good time to learn how to change the motor bearings . They are likely under $20 ea. at Grainger or MSC. That motor will be in the $250 range. About the only special tool you might need is a bearing separater. That's how I learned......
Davefr
OR
How many hours on the compressor?
Unless it's been heavily used it's probably something simple. (maybe the centrifical switch or some debris between the stator and armature or the cooling fan.)
It could also be loose housing bolts causing the armature to lock up against the stator.
I've also seen pulley keys get loose and jam between the pulley and motor housing.
It's definitely not a capacitor issue and I doubt it's bearings unless it's had a lot of use.
Just take it apart and see what's going on.
Mandres
and please post pics when you do so the noobs like me can learn from your experience!
Ben Buck
S. W. Ohio
:scared: I hope you didn't use any type of extension cord ? Remember to take the air to your work, not the compressor, just sayin' . :dunno:
PRH44
Indiana
Be sure the the rotor is or damaged. Items get handled rough in shipping. The motor could have been hit hard. Sometimes the rotor gets shove end to end. This results in bearing damage and some times in extreme cases the rotor comes in contact with the stator although rare.
Steevo is correct I have one of these compressors and the motors are low end. If its not under warranty its worth pulling apart and see if it is a cheap fix,at least see if you can some hours out of it. The motor is not worth taking to a shop in my opinion.
Davefr
OR
He could be right. This compressor is very top heavy. It could have easily been knocked over while in the store or during shipping/handling. I've seen display models in Lowes that were damaged. (bent cages and broken cooling fins).
Let us know what you find. I think I have the same compressor if it was from the Lowe's killer deal closeout last year. You should also double check the warranty. Some of these units had a decent 3 year warranty. (I'd still take it apart though in case it is something simple).
