Automatic Garage Door Closers
LazKat
Foothills of the Blue Ridge Mountains
FNG here with a second post. :D
Last year, my wife called me at work saying she was on her way to drop the kid at school then go to work, and she thought she had left the garage door open. "And that's my problem how?" I asked. "I have to be at work today!" came the reply. I'm 23 miles from home at this point, so I called my neighbor who looked and he said the doors were both closed.
Two weeks later it happened again. Phone call to the neighbor confirmed the doors were closed.
A few days later I had two Garage Butlers in my hand. "How much did these cost?" my wife asked. "About $150 or so." She asked "Isn't there a cheaper solution?" I cashed in a lot of spousal good will with my reply of "Yes, you be a responsible adult and close the *&^@! doors!!!"
I liked the Garage Butler units because although they're all hard-wired and a bit more work to install, there's no batteries to replace. The brackets supplied didn't work so I fabricated new ones from sheet aluminum. They use reed switches which I now have activated with rare earth magnets (salvaged from old hard drives) which I've riveted to the garage doors.
The units work beautifully and are set to close the open door after 10 minutes (they may be set to close after as much as an hour or put on hold altogether).
Looking at it, I wonder what else might go wrong. Let's see... wife goes out, round to the back yard... door closes and she's locked out. My fault no doubt! :headscrat I'll put on a keypad! Let's see... keypad batteries die, wife is locked out... again, my fault. :( I found a hard wired keypad that works perfectly and there's no batteries to replace anywhere in the system! :thumbup:
The only scenario not covered is a power outage... but I don't cover acts of God! :wtf:
Anybody else using something like this?
Gary S
Bismarck, ND
Keep in mind that I've seen more garage doors open from electronics failures than from people forgetting them. (You just added more electronics.:scared:)
crewchief888
NW indiana
i'm more of the
"close the f*kin' door when you leave"
kid got her feelings hurt, but it'll never happen again.
:beer:
langss
California
Had the exact thing happen to me. I came home from work to find the Garage Door wide open. My wife was home so of course I was concerned for her Safety. She was ok but had no idea the door was open. No remote opener, so it had to be something wrong with the opener itself. Needless to say its only plugged in now when I need the door to go up or down.
Stuart in MN
Minneapolis
I've seen ads on TV recently for a new opener from Sears that you can monitor on your smartphone, it also has a feature where it automatically closes after a set time period.
Personally, I just made it a habit to wait for the door to close before I drive away.
AndyL
Vancouver
aka liftmaster internet gateway http://www.liftmaster.com/consumerweb/pages/accessoriesmodeldetail.aspx?modelId=2407 (craftsman is made by sears)
If you have a server PC at home, or hackable router - a *71 remote can have the DPDT switch wired into a relay - So with something like http://www.phidgets.com/products.php?category=9&product_id=3051_1 you can send an open/close signal . Did this for one customer before the commercial product came available, simple magnetic switch on the door + this wired into the Liftmaster remote - made for a sweet little web interface...
FltEngCPO
Moore, Oklahoma
I just put the Craftsman (chamberlain) door opener with remote access and battery backup on my shop main door. You hook up a simple unit (comes with) to your wired network and then set up the Craftsman app on your iPhone or bookmark the website. Both require a password to access and the app will graphically show the door open or closed. Me likey, but I am a geeky gadget kinda guy anyway.
calven
Indiana
If you are willing to spend a little $ you can get a Liftmaster Model 8550. It will solve just about every problem you stated. It has a wide range of capabilities....but is pretty expensive. Sears sells a cheaper version (craftsman brand) that does much of the same.
1) Batter backup (power outage no problem)
2) Keypad (if locked out)
3) Regular remote control
4) MyQ technology (open/close your door with iphone or android app anywhere in the world)
5) Forget to shut door? Automatically closes door after a few minutes of opening -programmable.
