Metal pegboard
Dick in Wisconsin
Shawano, Wisconsin
Available in galvanized steel, aluminum, and stainless. Natural and painted.
Anyone use it? Work OK? any problems? I'm sure its very durable and looks nice. Worth the expense?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
It looks nice and it works. If you are willing to shell out the kind of money they want for it, then by all means get it. The panels are flat and you can get it in different colors. With the Masonite Pegboard, you are limited to brown or white and if you want a different color, you have to paint it. Also the Masonite pegboard has a little flex to it unless you get the heavy duty board.
itsspeeds
Menards sells gray pegboard. Here at mine its $25 for a 4x8 sheet and since it has to be special ordered, you need to order at least 5 sheets. Thank God I hit the jackpot at a builders auction and got a pallet of about 80 pieces of 4x4 sheets of gray and black pegboard for $40!!! Gonna use it all the way around the garage.
lotsoftools
Inland Empire
The tool room at school is about 10' x 15' and all the walls are covered with aluminum peg board. I can't imagine how much it cost, but it is cool.
