Red Leader
Looks like a fun saw project ahead of you. I looked twice but must have missed it - what diameter is that blade, anyways?
The blade that is actually on this saw, oddly enough, measured out to be 13". The Red Star 40A came with a standard 12" blade and blade guard with an optional 14" blade guard. Looks like this one has the optional blade guard, as there is a little bit more room in there, seemingly for a larger blade, which makes me super happy because I wanted a saw big enough that would allow me to cut 4x4s.
Awesome/
Wondering how you are gonna tackle that cabinet - you are a real optimist Red Leader!
Yes, the cabinet is going to be a delicate operation. The good news is that only 1 side is significantly pitted to the point of it being compromised. That side was shown in the pictures above, so that is the worst of it. What I am thinking will be to rig up a electrolysis bath and carefully remove the rust on each individual piece of the stand. It will be extremely helpful that the stand comes apart (bolted together rather than welded) so I can manage it with electrolysis. The electrolysis is the absolute least invasive method for removing rust. Instead of grinding the sides down until the metal is flat and making it significantly thinner/weaker by removing good metal, the electrolysis will take care of the rust and they I'll be able to fill in the pits with Bondo to maintain near the original thickness. I'm thinking about picking up some of that Bondo that is reinforced with fiberglass to add just a little more strength to solidify the cabinet. The corner pieces are not as pitted and are thicker sheet metal so I'm not super worried about the structural integrity. To be honest, with the right resources it would probably be easier to just cut and bend new sheet metal sides since they are basically squares, but since I am trying to preserve as much of the original saw as possible, I'd first like to explore this route. Plus I have no metalworking tools or skills. Plus it sounds like a fun challenge
I'm not sure if you notice, RL, but that is NOT a Craftsman saw...so, I am going to have to drive over there and remove it from your premises. Hee Hee. Just kidding.
I've been thinking, as I look at the OUTRAGEOUS prices people are asking for those newfangled sliding crosscut miter saws (new or used), that if I came across the RIGHT radial arm saw, that might be the better answer. Yours looks like the right radial arm saw.
Cool find. Looking forward to seeing it, after receiving the 'RL' treatment.
M_P
I know - it actual has nothing to do with my garage build. It is not Craftsman, and it is not even from the 1950s. Heresy!
Radial saws are pretty cool. They have fallen out of favor but if you get a good one and set it up correctly it can be very accurate as a crosscut machine. You are right - new, most of these saws equated to thousands of dollars when purchased. There is probably no other tool that has a sharper decline in resale value than a RAS. Most people just don't use them anymore. For most of the work people would use them for, a miter saw took care of 99% of that. When you want constant repeatability and need to cut something bigger or wider, a RAS can have its merit. When I worked in the stair company, I used a RAS every day. No way would I try and throw 30lb 8ft boards up onto a miter saw. We used the miter saw for the trim work on open-end stairs.
I'll enjoy having a miter saw in the shop at some point, too.
