Compressor drain plug just spins ...now what?
bjaspud
Cleveland, OH
The drain **** on my compressor just spins. I think the 'wing nut' portion is no longer attached. I tried to unbolt the entire drain plug from the compressor tank but the brass fitting just stripped.
What's my next step?
Spud
Gary S
Bismarck, ND
What stripped? Remove with a Vise Grip. Drill it out if necessary.
Let all the air out of the tank, remove the petcock and put in a new one. Problem gone.
reptilezs
same thing on a compressor at work. wing nut spins. just pulled the whole valve off and put in a ball valve an some elbows
bjaspud
Cleveland, OH
The compressor is built in under my workbench. Its gonnna take some excavating to get it out and turned upside down to really get at it properly.
Thanks,
Spud
gatchel
West of King of Prussia, PA
This seems to be the best fix for this problem. Replacement drain valves seem to always leak eventually, anyway.
If you can get your hand in to turn the valve, you might be able to remove it and install a street 90 to bring the ball valve to the outside of the structure.
