things need to do before sheetrock
maching
i built a 22 x24 and sheetrock is going up next month.
i have speaker wire, air, bathroom and outside water, plenty of outlets and lights. I made a nailer for my cabinets. I have my heater all set up. I also have 2 ceiling fans.
what else am i forgetting or anything i should add before i sheetrock?
Is there anything you wished you did before you sheet rocked your Garage?
D.J.
New Haven IL
I wish I would have went nuts with a camera and took more pictures for future use in my house, but I can't see why a garage would be any different.
allinon72
Indianapolis
Put supports between studs where you know you'll be hanging things. Take pictures of all walls so you can use them as a reference of where things are.
machine_punk
Napa Valley, California
I know it's a garage, but run internet, computer network (Cat 5E), and cable TV wires out there too.
You said you put in plenty of outlets, but I would make sure there are one or two 240-volt outlets (a 30a for an air compressor and a 50a for a welder).
And, you didn't mention it, so I will suggest insulation, if you have not.
M_P
Dan in Pasadena
Pasadena, CA
Did you install those metal plates on the studs where the Romex runs through so you won't accidentally drive a nail or a screw through a line?
Larry_AZ
Goodyear, AZ
I second the Internet outlets, and label them if you add more than 1 line.
You might want a couple of 110 outlets in the ceiling for drop lights, reeled extension cords, etc.
Canned lighting in the ceiling?
Multiple attic accesses?
Good look with your build.
Larry
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Why is that? It's plumbing. Do you have your water lines on the outside?
You know, if you do a good job, it should last a lifetime.
You would want drain valves coming through the wall at low points. Maybe just below your connectors if plumbed down from higher.
Nothing new, no big mystery, air distribution systems are an established technology.
The air lines need to be in free air for cooling purposes in order to condense and separate moisture efficiently.
Examples of proper air system construction and installation have been posted here and on the web for a long time. Unfortunately there are also improper installations posted here.
ROCKNMUD
Southern NH
Run garage door wires for sensors and opener button at door. Looks so much nicer than wires running across the ceiling and down the walls.
maxspeed96ct
Why run internet wires when wireless is so cheap and easy , but as far as cable wire I would def run that incase you wanted to add a TV down the road .
djkeev
North Western New Jersey
Vapor barrier before Sheetrock.
I too agree, photos of each wall before finnish panel, add dimensions written on studs for any critical dimensions such as height or distance from corner.
Hanging anything from the ceiling? Lumber racks? A shop heater? Etc. block for them now so the are solidly affixed later.
Also more outlets than you already out in. You won't use more, it's just that the ones you put in are in the wrong places!
They are cheap and easy now, expensive and hard later.
Dave
HotrodHR
North Alabama
Last but not least...
Hire a contractor to hang, tape and finish the drywall!!!! :lol:
Save your back and unless you're really into it (and good at it) the results will be better. I know, you'll save some money doing it yourself...
My new garage is insulated, sheetrocked and being finished (almost done, another coat or so of mud) and will be primed. I priced the materials out and with borrowing, renting or buying a lift, scaffolding etc, I was only looking at a about $300 bucks in savings... My labor, headaches and hassles made the decision easy... not to mention downtime if I screw up my back...:lol_hitti
These guys make it look easy! 12 foot 4 inch ceilings make it a bee achh!
egads74
If you do a bathroom, do framing in wall where you would add hand rails (shower and toilet area).... at some point you will get old need that extra. doorbell. at a minimum I would do a 2x6 horizontal at 5 foot around the garage perimeter and then you always know you got a nailer there...
Cobra6
Tennessee
+1 -
Exactly - wireless is the way to go - you can extend from your house if you need to.
but you may need to run the coax for TV
Falcon67
Merkel, TX
+1 -
Or buy a LG Smart TV, or Roku. My bench is about 80' from the router through three sheetrock walls, brick wall, concrete siding, steel door and OSB. I get plenty of signal.
BlindViper
York, PA
Run a 2" conduit from the attic to the top of the service panel in case you wanna run new more wires in the future.
Mmfh
MEMBER EMERITUS
Portland Oregon
I just did mine and I already wish I had done something I didn't, put a outdoor plug receptacle for having power on the outside of the garage. Runs the wires for that plug inside of the wall, that's what I forgot to do.
How about a little "Time Capsule". You know the ones where you drop in something from that time period, take it out of the wall much later and look at what was left when the box was put in??? LOL.
Delta74
Peachland B.C. Canada
as others have said, Pictures, lots of pictures, close up of a tape measure for heights / lengths, pics of wire / conduit runs, nails some back boards for the cabinets you will add in the future, and again, Pictures with heights, dont forget the TV, and just run wire for net and phone ( hint cat 5 net cable will let you use 4 seperate phone lines if needed )
yes wireless works great, I Love driving by and accessing other peoples un secured and poorly secured net connections and accessing there info / wifes nakid pics. Wired net is one less hassle to worry about, for speed and stability.semi kidding about the above, but I find enough unsecured connections around town to make most paranoid about there banking info.
dirttracker18
Slate River, ON
An outdoor receptacle on every wall, outdoor lights on every wall on separate switches ( trust me I have used mine many times, all in the soffit with double floods). One 30 amp RV plug outside, just in case. I have friends that travel with RVs and they have full electric when they stay at my place. Plus I can work on my RV or use it when lots of company comes.
maxspeed96ct
You make a good point, Sheet rocking can be a pain. I want to do mine myself, I only have 9 ft ceilings. But it seems like it takes me 10x longer to do what a pro would do as far as rocking taping and etc.
I'll be getting some qoutes and really compareing doing it myself or having someone else do it
kenfath
Upland, CA
Pack newspaper inside your open electrical boxes, etc to keep them free of drywall mud and sanding dust.
