What to do with forklift blades?
ToddG
I can get 4 sets of forklift blades for free! Now what can I do with them?
91bronc300
Give your work truck 'fangs' by welding them outward and upward to the front of your truck.
T
ToddG
They are the flat ones and are about 4' or so long. Heavy little boogers! I'd rather make something cool out of them than sell for scrap...
jwith68
EC Missouri
My F-I-L snagged a set off a scrapped out Yale forklift, and they are now lifting stuff on a QA frame for the Bush Hog 2426 loader on my IH 574 utility tractor. Cost me about 20 - 25% of what a factory made set would have, and are better built. I'd have gladly given ~$150 for a pair of bare forks, had I run across any for sale.
CarterKraft
DFW
If you cut eye/hook end off and then cut them at the 90* bend the left over striaght section makes good press plates for your hyd press.
jlckmj
SE Wiscosin
I looked for a long time for a set in order to make a fork lift set up for my skid steer.
I ended up paying $200 for a good set of 4 foot forks and the rack they slide on, bought a quick attach adapter ($120) for the skid steer, and I had what some equipment shops are selling for up to $1,000, sometimes more.
Advertise them on Craigs list under bobcat, skid steer, and skidsteer, you will get good money for them.
Jim
zmotorsports
Northern Utah
This is exactly how I made my arbor plates for my press. I have used them for the past 17 years on my home press and they work awesome. I scrapped the remaining part of the fork as it is tapered.
Mike.
Boiler
Indiana
I would sell them as used forks, buy the right material for my project, and pocket the difference. Kind of dumb to take the value out of them
zmotorsports
Northern Utah
This would be a viable option as long as the forks were not worn beyond their safe limit. Forks should be taken out of service if their thickness has worn 10% from original thickness or more.
I couldn't in good conscience sell someone a fork that was unsafe, whether they were going to use it as a forklift fork or not. When we remove our forks at work they go directly to scrap after being cut in half so someone cannot inadvertantly use them and have them fail.
Mike.
CarterKraft
DFW
All 4 sets were taken out of service because of wear. I can't sell them as usable...
Tada!
Either way I would cut the taper off them and just store the steel, won't take up much room when trimmed up. The tapers would be good for making various tools (wedges etc) and the straight sections would be good for any thing in general. If you scrapped the tapers, maybe 3 of the 4 you might get some money to buy the used material, at the same scrap yard, to build the press to use the arbor plates for.:rocker:
