Multi evaporators on one condenser (mini split)
Grumpy365
Brazoria County Texas
Ok, I am worried this will get lost in another thread.
I am putting a mini split in a "Bonus room", but, I am seriously considering putting a second coil in the garage.
My question is on energy.
I know the compressors are DC, multi speed, and magic. My question is about the magic.
When I am only running one coil will the amp draw go down sufficiently? I am worried running more compressor (read $$$$$$$) than I need, since I don't intend on using the garage coil very often.
D.J.
New Haven IL
I was talking to two different HVAC guys and they were talking about using up to three coils on one condenser.
Jackfre
N CA
The dual, tri and quad units are not as efficient as the singles. For instance, I am putting in a dual 24 w2-12's in my daughters house this week. It is 16.5 seer. I did the upstairs in my home with the same unit, but rarely run it. In the downstairs I put a 25seer single 12 with 12hspf (heating seasonal performance factor). In your case, I'd go with the new 28 seer in the primary living space and go with a less expensive unit for the garage. Btw, they are making units now that are 4ton (48kbtu) and you can run up to 8 evaps with a total of from 38-64kbtu worth of evap. The numbers I've given are for Fujitsu's, but their numbers are typically the highest in the industry.
brihvac
North Wilmington, Delaware
To give you a simple answer....
Your not gonna use more energy than you need with a DC inverter unit. That is the purpose of it.
RKA
The other thing worth asking is what does the larger unit draw just sitting in an idle state. I have a 24K BTU Fujitsu single zone and it draws 270 watts when it's off. I thought it might be a heating circuit, however we've had temps over 70F already and it's still pulling that constant 270 watts (translation, no magic, $1/day to do nothing). Having two units on two circuits means you can shut off the garage unit completely and avoid a parasitic loss, but I don't know if the smaller units will draw any less than one larger unit.
Highbeam
Mt Rainier foothills, WA
270 watt phantom load is HUGE. Call the manufacturer, there must be a short. A single cfl light bulb is 13 watts. 20 cfls in one spot is like the sun.
Robleticia
Angleton, Texas
Daikin makes systems much larger than this, we just intstalled a 50 ton system with 38 evaps!
Jackfre
N CA
Absolutely! So do Mitsubishi, Sanyo (now Panasonic) and Fujitsu. Samsung and others do too! Sounds like a pretty cool system. How's it running?
