Stud Removal Tools
Stefan S
Texas
I need to remove and reinstall some studs on the top plate of a MacPherson strut assembly. What tools have you used to do this? I don't have room for a press so I was thinkig more along the lines of a specialized c-clamp.
Thanks in advance!
BlindViper
York, PA
If they are pressed in some washers and a nut might pull it out. If they are threaded you will have to us two nuts.
I have that craftsman extractor and rarely use it. I use the double nuts and lock them together method. Just use the bottom nut for the extraction so it is in "tighten" mode (Against the locking nut) instead of loosen during the removal process.
The only time the extractor gets pulled out s for studs that have had the threads snapped off.
Russian
Dickinson, ND
Agreed. I also prefer the extractor on studs with shoulders - like the last time I had to remove exhaust manifold studs.
garfunkle24
Saskatoon, Canada
I have used both the cam style above and also the sprag style stud tools. I always use the double nut method to install threaded studs as the actual tools damage the threads too much (if you can only get on the threaded part).
If I'm removing them and not re-using them I use the stud tools or cobras/pipewrench/whatever.
Stefan S
Texas
these are pressed in from the back of a coil over assembly - a nut or standard extractor will not work... there has to be a special tool for this I don't know about
Pics would help, but it sounds like you may need something like a Ball joint/U joint tool and some appropriate adapters...
richfinn
Leeds, Yorkshire, England
if you can support the top plate with a large socket under the head of the stud and a nut screwed on a few threads they will drive out easy with a hammer and starter punch.
glenmore
Los Angeles
I've never had the need to use these but I'll have them when the time comes!
A pretty old 1944 Snap-On A36, a 1947 Snap-On A50 with interchangeable bits and and old Proto Los Angeles.
Murphy4570
West Deptford NJ
Those old style extractors work, but they're damn beefy. They won't fit in tight areas, which seems to be the only area where studs are! :lol_hitti
