Renewing pin punches
browntown
Salem, OR
Stupid question, how does one grind old pin punch tips perfectly flat?
I have some old starretts that I've used and abused and the tips are deformed. I was just going to use the bench grinder but I wasn't sure that I would get a nice flat and perpendicular tip. My other idea was to chuck up the punch in the drill press and push it into a grinding stone or sandpaper.
Am I overthinking this?
Matt018
hmm a belt sander may be the best choice, I'm not sure, although I look forward to what others say
Kevin54
MEMBER EMERITUS
Urbana, Ohio
If all you have is a bench grinder, stack up some scrap 2x4's at the side of the grinder. Lay the punch on the 2x4's and roll the punch back and forth while dressing the punch on the side of the wheel. Same way if you have a belt sander, roll the punch to get it perfectly flat.
larry_g
oregon
I chuck up the punch in the hand drill and spin it while running it against the grinder wheel. Make sure that the punch is perpendicular to the grinder shaft so as not to leave a point on the punch. I do not use the side of a grinding wheel as it will weaken the wheel and lead to explosive failure.
lg
no neat sig line
wornoutoldman
Conover WI "God's Country"
lg
no neat sig line
Yikes! :willy_nil Do not use my intial suggestion unless your grinder wheel is designed for side grinding! Thanks Larry :thumbup:
Robbie UK
UK
Drill press for me using an old sharpening stone (the flat knife sharpening kind) to gently grind against.
