Garage, shed, and house build
A
ajbancroft
Carmel, IN
the house before and now:
A
ajbancroft
Carmel, IN
Hauling home the galvanized roofing on the family truck:
Menards roll up door installed:
This is as far as I got lt fall, before it got too cold:
I started back up this spring by using the laser cutter at work to cut out my window shapes:
close up of the panels:
Test fit of the windows:
A
ajbancroft
Carmel, IN
So I have high hopes for the garage, which I've basically saved for last. Sketches to come of how I want to reconfigure the toolchest and overhead cabinets; I want honest opinions. I've also been reading the flooring forum, and it looks like I'm going to need to rent a diamond sander to get the old paint up off the floor...
PECVD2
Albuquerque, NM
Very nice job on the home remodel but you need a VW emblem painted or hung right above the TV (actually just paint that hood in the garage and mount that.
I really like the clearstory windows on the shed ( I used plexiglass 4"x11.5" on mine) and the repurposed kithen cabs look great.
JMURiz
NoVA
Nice clean look to your projects!
I like your home-made version of the Modern-Shed, I REALLY like the storage unit roll up door.
A
ajbancroft
Carmel, IN
The door came from Menards, and if I could have settled for a stock size and white, I could have walked out the door with one for $159. As I wanted a custom size and color, I had to wait a month or so, and pay $179; not too bad in my book.
A
ajbancroft
Carmel, IN
instead of start an extra thread in the flooring section too soon, I thought I'd give a shot of asking here; also, I feel like I know the answer. I think I need to rent a floor maintainer with a diamond disc to get this all cleaned up. what do I do to it after the paint is removed?
any idea what product might be on the floor already? I did the below with my dealt grinder
A
ajbancroft
Carmel, IN
to grind it myself, the tool rental will total over $550, plus the rental of a truck to get it home. a professional concrete polishing guy quoted me $2500 just to grind it down, a little less if he could get to 220v; I was floored! I wasn't expexting dirt cheap, but on the phone he said a mid-range job would run $6sqrft; and that was grind + polish!
atxgsa
Try home depot rental section. The orbital walk behind polishers ( I am probably calling this the wrong thing but you get the idea I hope) also can be used with a scraping disc for the same effect for much less.
Before you do that though also go talk with a sherwin Williams paint store ( or comparable) and see if they have an acid product that will peel it away chemically. Several people mentioned this to me after I had scraped 1700 sq ft of paint off of the foundation floor of the last house we gutted. Do the research first :lol:
This was our final result after two years of remodeling.
http://journeylab.smugmug.com/Architecture/2905-Inridge/21706141_h62NvC#!i=1730968350&k=MhJmhHF
Enjoy, darin
sneakyfast
Really bad, quick viz:
Before, but in progress:
After:
Good looking work. I love the gray color of your cabinents out in the garage. Its funny I have several of those pepsi wooden containers I use to hold stuff out in the garage and hadn't thought about using inside. I would also suggest that you put a faucet on that sink as it makes it easier to direct the water. :thumbup:
A
ajbancroft
Carmel, IN
I painted everything and added trim. The way the cabinets were bothered me, so I rebuilt and rehung all of them. New doors make a huge difference.
A
ajbancroft
Carmel, IN
I'm thinking a secondary garage is next. I had a builder quote a 20x20 complete for $15k, which leads me to believe I could go a little bigger, and build for a little less. Storage for the beetle and it's parts + one other car. I think I'd like to match the style of the shed, but stay a little more conservative in the siding department.
Sunbimmer
The province of Limburg, The Netherlands
Wow man my compliments on everything :thumbup::thumbup::thumbup:
That's a fantastic place you have there, everything the house, the garage and everything you have done to the place.
I've never seen this thread before but I'm glad I found it. You gave me inspiration.
I especially like the color green you used on your garage cabinets.
My hanging cabinets will be red and the rest of the cabinets under the workbench will be green like yours.
You gave me an idea of how it will look like, thanks for sharing.
A
ajbancroft
Carmel, IN
Well, I've been waiting to do this for a long time. I finally got around to drafting up what I want, and have found contractors to help me with what I cant. Actual pictures to come eventually:
