Ford 1715 tractor pentagon socket
StevenB
CA
Got a Ford 1715 tractor that's leaking diesel at the fuel regulator, the problem it has a pentagon bolt head. I've looked around and couldn't find close to its size.
Any help on locating a tool would be greatly appreciated.
Sam B
How tight are these bolts? Personally, I'd try one of those Gator Grip sockets, lol.
Probably not a popular answer, but I have one and use it on Honda/Acura spare tire hoists (five-sided crank). Works every time.
StevenB
CA
Don't know how tight they're. The gator grip is a good idea, but not sure if there's enough room for it to fit.
Davefr
OR
For some tasks you have to make a wrench. Get a HF wrench that's one size smaller and grind/file to obtain a custom fit.
HF wrenches are cheap and easy to modify.
Solo
Will one of the universal sockets from craftsman work on It?
Solo
marslawn
Gorst WA
I had the same issue one time. I took a small air grinder I had and ground down the bolt.
I find it is easier than trying to find the special tool all the time.
Hope you get it tight!
StevenB
CA
I went to hd & got the gator gripe & it didn't work.
Come to find out the pentagon bolts don't have to be removed to fix the problem. The o-ring on the injector sets on the plate that the pentagon bolts hold down. The injector screws into the block.
All is good, still have other problems to fix on it.
