So, what do you use 1/4" drive universal sockets for?
iroc409
So, I bought a full set of 1/4" drive universal sockets in metric and SAE, well, because they were on clearance I guess. :lol_hitti
I could see using the swivel sockets on certain things, especially in today's cramped engine bays, but it seems like the 1/4" drive will be too fragile for most things. I thought maybe working on interiors would be handy.
I'm not sure if I should keep them, find someone who can use them better, or just return them. Or, maybe just keep the metric set, since our cars are metric.
mossyboy6
St. Pete, FL
I was thinking about how mine just always sit around in my box and how useless they are, but then I remembered that I have used them. It was on a trunk latch, that was very hard to get to, and they definitely saved me a bunch of hassle.
With that said, that is literally the only time I have ever needed to use them. I do have a set of 3/8 that I use all the time.
If they made a semi deep 1/4 set with thin walls, I could see it coming in handy for some stuff, but most all of the small bolts on cars are on studs that stick out far, not allowing you to get a super shallow universal on.
Just my personal experience, I am by no means a professional.
keithwvd
at the shop I use 1/4" swivels on a daily basis. thermostats, sensors, interiors, emissions **** that's tucked up above the rear suspension and tank, all kinds of engine covers and inner fender plastics with a 2 foot extension so I don't have to bend over or reach at all, etc
I use them with a 7"-ish long locking flex handle matco ratchet and it's an awesome combo, I break loose tons of things I should really use 3/8 for but the ratchet and sockets are holding up so I don't bother to make an extra trip back to the box
I
iroc409
Hmm, all good things to ponder. I was getting set to just return the SAE set, but I didn't think about small engines. Although, right now all I have is a Honda mower and it shouldn't need much work for a couple years.
NUTTSGT
Northern Central Ohio
They were on sale, you had to buy them. If you got a good deal on them, why not keep them ?
What I mean is, you've already bought them and the money is gone (invested in a tool), spend a different dollar to buy a different tool.
aussiek2000
not Australia
I use mine everywhere you can get a straight shot at the bolt.
Just today I used my 1/4" and 3/8" on spark plugs, t-stat, hose clamps, sway bar bolts, etc.
Humble Mechanic
NC
I use my 10mm ALL the time. I also use my 13mm a lot. May of the things everyone else said. I would say, just keep them, you will need one as soon as you return them
dwp99
West Coast of Florida
I use them with my SO power screwdriver on dash boards, heater cores, coil over plug coils hose clamps and just about any small fastener.
csmitty
I've had a SK 5/16 for a while, awesome on hose clamps. I got a few of the CMan, not a whole set as they weren't all on sale for some reason. But as easy as that 5/16 makes it was hard to pass up others. Even though I have a 3/8s set that goes down to 3/8. However the 1/4 will fit in more confined spaces.
Only got a 13mm in metric. Was hoping the 10mm would ring up but no dice and no convincing. Those two would probably be the only ones i'd need.
greasemonkey44
memphis
heh i use the hell out of my craftsman 1/4 wobbles
intakes, hose clamps, thermostats, oil pans, heater cores
they are fantastically handy if you have to deal with tight spaces
House Sparrow
Lewistown, PA
I use them a good bit. In some cases, they can be the only way to reach a nasty little bolt or screw without an extra hour of ripping things apart just to get a straight shot at it. I use them a lot on sensors, thermostat housings, coil-on-plug mounting bolts (especially on V8s), oil/****** pans, you name it.
pipsters
USA
I just picked up another Cman 1/4" set MM set on sale for $25, about half off. Not the best price but I use the 1/4" stuff on my air ratchet and it tears stuff apart pretty quickly.
Big Omega
Is there any benefit of using a flex socket over a universal joint and a regular socket?
unslow1
Illinois
I used my 1/4 flex 14mm tonight to put wheels on a toolbox. Cordless drill with a 1/4 adapter bit and it went fast.
earlthegoat2
SE GA
1/4 universals are great for use on outboard engines. That is the most I ever used them for and that is the reason I got them. Since I dont work that job anymore I never use those universals anymore.
