oilslick
Anybody do a homemade air to water cooler for a garage? I was thinking just burying a 1000' of 5/8 pec and running it thru a radiator.
hydronic cooling system like you speak of making will not work. You have to supply with cooler than 50 degree water to do any work. Chilled water systems operate at 44-40 degree water temps.
Geothermal systems utilize the 52* ground water temp as a condenser that takes place of the air to air condenser in your house, still has a compressor and refrigerant supplying an evaporator coil.
It won't work
Thanks for all of the ideas!
