What is the acceptable line voltage from the power company? I am currently getting 244 and 122. Which would not be a problem but it is causing an over current draw on a motor I have that is running off a step down transformer.
-Dan
-Dan
Higher voltage will reduce the current draw of a motor, so if you have an overcurrent situation, you have another problem.
I agree with Stuart, what kind/type of motor is it?
Things like light bulbs would burn out way to soon maybe twenty+ a year. I would blame the kids for leaving them on all the time (sorry kids) But I cheeked my voltage and it was 132v 247v
I know it took ten years to cheek
After a long talk with the power Co. they replaced the trans. Haven't replaced anything now for six years. And for light bulbs
)This is wrong. As you stated above the formula for amp draw is
Amps=Volts/Ohms
This means that for a set resistance, i.e. the motor, That an increase in voltage will mean I higher amp draw.
You saying that the Voltage drops to 1/5 at start??Motors can draw more than 5 times their amp rating on start up,
Tom
Actually, at startup, the reason an electric motor draws significantly higher current is because the motor is not turning at that point, so it looks similar to a dead short. When energy flows into the motor, the electricity produces a magnetic field that generally opposes the magnets around the motor, causing it to spin.If this is true
William...
If this is true
William...
Back to the OP question. 122VAC is not considered over voltage for a 120V system. Its been too long to remember the exact limits, but 5% rings a bell...
The windings in a standard induction motor are switched on in off in succession to allow the next winding in series to attract the shafts magnets. Otherwise the stator would be pulled to the first set of winds and stop. When the shaft first begins to spin, this switching is delayed (i.e. each winding is on for longer) allowing current to flow unchecked through the windings. The windings are typically very low resistance and are nothing but very thin long wires. The magnetic fields in motors actually help to limit the amount of amperage that a winding sees, but when a motor is switched on those fields take time to establish and in that short period amperage can be 5-8 times running amperage. It is known as Lock Rotor Amps, and is just what it sounds like, the amperage through the motor windings when the rotor is locked in position and cannot spin.
Tom
My point was that you said
"This means that for a set resistance, i.e. the motor That an increase in voltage will mean I higher amp draw"
I took that to mean that you thought the resistance was fixed on the motor. That's why I asked you if you thought it was 1/5 the voltage due to the amps=volts/r relation.
As for the above description, of the operation of an induction motor, it's quite unique..... You do know that the rotor has no magnets in it, but rather it's an induced current that creates a magnetic field??
William...
