JDewey
Long time in the planning, I have started building my "retirement home". It is a 40' x 50' welded steel building with a 24' x 50' overhang on the front. 15' walls with 3/12 pitch roof over the shop with the pitch running front to rear, with a 1/12 pitch on the overhang. Shop doors are 12' x 12' and 18' W x 10' H powered roll-ups with a people door on the front. Front of shop (door side) will have brick up 4' and the front support posts will have brick all the way up (around the support beams). There will be a separate 5' x 10' pad on the side for the HVAC heat pump and compressor mounts. Service will be 200amp, 230-single phase.
I got homeowners approval on Friday, 4/13, met with the contractors on Monday and construction started on Tuesday. On Tuesday (1st day of construction), the contractor cleared and mulched the trees and brush, cleared the stumps and started laying the driveway base material. Good progress for the first day. Some photos below.
