Hose Clamp Pliers?
CatfishXpress
A big piece of steel in the Gulf of Mexico
What's everyone using to remove hose clamps like these?
I have been using channel-locks, but when they are in a hard to get to space, it can be very frustrating. I'm ready to buy the right tool for this job, but a search revealed several different types of pliers. Which works the best?
PowderKeg
Little Rock, AR
Does the remote portion of those pliers grip the hose clamp ends firmly without letting it slip off and go "ping!!!"? Might have to make room in the plier drawer for a set - or better yet, another reason to buy a bigger top chest....
C
CatfishXpress
I'm definitely trying to avoid the "ping".
I hate those kind of clamps, everytime I get one off, its replaced with a stainless steel old type hose clamp.
Has anybody tried this style? KD tools part number KDT 3706
PoorOwner
CA
I think I will pick up a craftsman soon and let you know..
I rather spend $40 to have the tool than not wanting to spend $80 and have no tool :)
Merkava_4
Clovis, CA.
I'm wondering what the advantage of having the right angle configuration as opposed to being straight like the Craftsman pliers would be. :headscrat
Fedwrench
Valley of the sun
I think you need to lay the Mayhew version on top of the Craftsman version to see if the handle spread is the same size. How big are your hands? Does the right angle provide you with more leverage?
As I have posted before, you want a set with a ratcheting lock for ease of operation. I haven't found a dealer yet that will warranty the cable assembly.
Joe B.
Here is the patent that is stamped on my Craftsman version. The patent was issued in 2001 so we won't see a copy of this one for quite a while. It even has separate drawings for the straight and 90-deg versions but I'm too lazy to read what the difference is. It is amazing the price range you see on different versions of this tool.
http://www.google.com/patents?id=tbsEAAAAEBAJ&dq=6189190
<a href="http://www.google.com/patents?id=tbsEAAAAEBAJ&zoom=4&dq=6189190&pg=PA3&ci=49,207,859,1056&source=bookclip"><img src="http://www.google.com/patents?id=tbsEAAAAEBAJ&pg=PA3&img=1&zoom=4&hl=en&sig=TCl5ESDBfVlTG7K9esG-0j8rRGE&ci=49,207,859,1056&edge=1" border="0" alt="Text not available"/></a>
<a href="http://www.google.com/patents?id=tbsEAAAAEBAJ&zoom=4&dq=6189190&pg=PA3&ci=49,207,859,1056&source=bookclip">System for the remote handling of equipment particularly adapted to elastic rings Pascal Gillet et al</a>
PowderKeg
Little Rock, AR
Fedwrench
Valley of the sun
That is the ratcheting type. I don't think ratcheting is worth another $100.
I don't think any hose clamp pliers are worth a $100. The prices on the SK site and SK stuff at sears online are pure insanity. You can easily find those pliers for $65 or so if you shop around.
I can assure you that the ratcheting locking teeth are worth the money especially if you need to pause while compressing a clamp to reposition it or to adjust it.:thumbup:
64merc
Texas
Huh, I thought all hose clamp pliers like the Crafsmans linked to are ratcheting???
Stephenw
Utah
The spring type clamps are actually superior to the old style worm drive clamps.
They are called constant tension clamps. As temperature changes, they maintain a constant pressure on the hose to prevent small leaks.
The old worm drive style clamps have a fixed pressure. As temperature changes, their tension changes, either increasing or decreasing. This can result in small leaks or seepage.
wythors
The tips of the clamps seat into two very deep grooves in the jaws of the pliers. I've never had one go "ping" and I think you'd have to try pretty hard to make it happen.
Merkava_4
Clovis, CA.
This is very true. :thumbup:
eschoendorff
Mine on by 1994 Chevy Silverado must be deteriorating, because they don't seem to be keeping a good steady pressure on the hose... things be leaking. I was gonna replace the hose and get the worm clamps, but now I think I'll just get new spring steel ones...
bchee
Texas
are you guys messing around or what? It's a single click ratchet mechanism, so technically it ratchets? pure evil
wilbilt
NorCal
Actually, I don't own one, so maybe it does click more than once.
I am almost always messing around. Hopefully, people don't take my comments too seriously when I am in humor mode. :beer:
