Andy Griffith
Looking at constructing a 12 x 16 building (shed) on 4x6 skids, on our rural mostly undeveloped property.
I've been reading some of the back threads on T 1-11, and pricing out materials for the build. I like the look of hardieplank better than sheeting but I'd rather not mess with the additional materials and work involved with planks, and for where this shed is located appearance is not critical.
My experience with T 1-11 plywood as been pretty good. It lasted 40+ years on our first home. Not sure if current T 1-11 plywood can last as long as the old stuff or not. Curious if anybody has had experience with this hardie plank fiber cement type vertical siding?
While in Lowes I found Hardie Panel vertical siding which looks to be a clone of the T 1-11 in terms of appearance.
Pricing.
Hardi Panel = 28.52 per sheet (sierra 8 style)
T 1-11 (plywood, .578) = 36.08 per sheet
Some Hardi panel specs.
- Comes primed, must be painted within 180 days
- Can't be stained
- Recommend power driven nails
- can be installed over wood framing/studs up to 24" OC
- galvanized or stainless fasteners required
- 30 year non-prorated, transferable, limited warranty
http://www.jameshardie.com/homeowner/products_siding_hardiepanelSiding.py?search_zipcode=retail
http://www.jameshardie.com/pdf/install/hardiepanel-hz10.pdf
Pricing.
- Can't be stained
