NASTYZEN
I recently had a customer send me some Alu. tubing to bend up as waterlines for a Migal race car. Problem was it was 30 mm dia odx 26 id. Darn I have only Imperial sizes for my mandrel bender.
Time for sand bending.Old school at least my take on how it's done. This method works on steel tubing as well.
Step one, use 6061 T-4 Aluminum tubing for this to work. It is softer than T-6 and can be bent.
step two, plug one end of the tube.
step three,fill with silica quarts sand tapping the tube between each cup of sand to pre compact a little, be careful not to dent it ,T-4 is soft..I like medium grit sandblast sand the best.
Step four,
Once filled insert a loose fitting plug into the tube. I like to have a champher in the plug to keep the threaded rod centered.
Step five weld a threaded plug on the end of the tube.
Step six, compact sand by screwing in threaded rod till tight,then bounce on floor a couple times tighten a little more and so on till it's really tight.
Now were ready for bending.
I have plenty of material so I'm going to try a test. Instead of using heat like the traditional way,I'm going to try a bend in my home made mandrel bender,cold!
How daring!
The tube set up in the bender. I found 1 1/4 in. was just over 30 mm.
Ok bend!
DoooH!
Didn't get very far.
Step four,
How daring!
Ok bend!
DoooH!
I always wondered what it meant
