Norm likes hydronic but I'm having a hard time with the initial outlay. I'm in Hickory NC, and while we do have winter, it is usually on the mild side. I'm more concerned about cooling in the summer, which can be toasty. I read where condensation would be an issue if one tries to run chill water to the slab tubes. I'm leaning toward a standard electric heat pump and would like to hear feedback. Shop size is 26x40x10. Walls are 2x6 and truss bottom chords are 2x10 and I plan to insulate well. There will be a single 16x7 1/2ft garage door on the front gable end. No plans to condition the attic space but will be able to run ducts in the knee walls. Comments, please.
According to the philosopher Jagger, "You can't always get what you want, but if you try sometime, you'll find, you get what you need."
