Tow point or in-floor anchor suggestions
matouse3
Mid-Michigan
Concrete is going to get poured soon and I'm wondering if I should put any anchors points into the floor? Any suggestions out there?
Thanks in advance for the help.
Rigpig
Victoria,BC
bad_idea
Pasquotank, NC
an anchor point on the backwall centered to the roll up doors are good for winching in dead vehicles. pull pots are the strongest/cleanest option.
sfckiddo
i used pipe about 6 foot long, saddled a shorter piece in the center with chain inside it attached to the long one. Four links pull above the top to hook to. Covered it with duct tape when i poured. Put in 8, 3 on one end 3 on the other and one on each side in the middle of a 16x30 so can tie off any where. Put them down before the wire so will have to pull the floor up before they come out.
brownbagg
like the guy above, I did the pipe with the chain deal. got four of them, so if I ever have to pull a frame, I can anchor to one of the pots and winch off the others
