Lug Stud Remover or Steering Gear Arm Remover or etc...
BrianAltenhofel
In a trailer somewhere in the country
So I learned the hard way a couple of years ago that beating a Wal-Mart broken stud out with a hammer bends aluminum hubs. I guess I didn't learn the lesson about letting them mount my tires, though.
I was doing a brake job the other day, and lo and behold I break another stud. Actually, I was cringing as I was taking the nuts off, as my impact would not break them loose. I finally got them broke and off and everything seemed fine until... I get the last one started back on and then the stud breaks.
It seems the "right tool" is a C-4150 that Chrysler seems to use on half the steering and suspension parts on the LH platform. It's basically a C-clamp with a hole in the base of the C to push the stud out through.
I spent an hour at O'reilly yesterday looking through their tool catalogs, and found one, but the vendor no longer sells it. I can't find any information anywhere.
So my question is, will a properly set up shop press work just as well? I have many to choose from at work. If all else fails, I *could* make my own, but I really need this car back on the road fast. (It has A/C, my wife's doesn't.)
eschoendorff
The tool you are describing sounds a little like the HF ball joint tool, but I am sure that you probably already tried that...
BrianAltenhofel
Right, it is too narrow (arm is too close to the screw). The one that is included in KD-3421 is what I have tried, and IIRC the HF one is the same size. But if I were to drive to OKC for one that fit, I might as well just buy a new hub assembly.
eschoendorff
I see what you mean. In the end, a new hub assy might be the path of least resistance....
Elroy
kentucky
Why wouldn't a hammer work ? They are not pressed in THAT tight. Don't worry about the bearing thay can take a lot of force. Install with a nut and some washers. Get on with it and don't go back to Walmart
BrianAltenhofel
The first time I had to do it, I used a hammer. It came out, and the hub had a new curve to it and the hole for the stud was slightly out of round. A hammer works great on steel, but not on aluminum.
I hate that the bearing on these hubs is sealed so that if you do have a bad bearing, you have to replace the hub. $30 bucks and some of my time to repack a bearing is much more appealing to my pocketbook than $100 for a hub assembly. Same thing with a $2 stud.
Moose-LandTran
The Brink of Insanity (England)
Use a vice, open the jaws so they're apart, just slightly more than the round "base" of the stud. Then whack it with a hammer. Works the same as the press, doesn't bend the hub.
That's what i've always done when i didn't think it was safe to smack them out in situ. Never had a comback from it.
Elroy
kentucky
Take it back to Walmart and have them fix the dam thing. A good ***** might even make you feel better. It's obvious some Walmart jerk had no idea how to use a torque wrench. Point out to them that their fault placed your life at risk.
Elroy can't believe a hammer won't work. If you're worried about the flange, back it up.
jay50
Put it in a vise and use air hammer with pointed attachment to knock it out
russlaferrera
Central Virginia
Air hammer will drive it out. or put a receiver nut/socket in the rear of the stud and use a smaller dia. nut/socket as a driver (if needed), with a c clamp
