Drill press has no torque
Concrete B
I have a Ram Machinery 16 speed drill press. It has lost it's torque and won't drill at all. I don't have a clue as to what's wrong or where to start. Any help?
osborn.ozzy
Charleston, SC
Does the motor bog down? or does it maintain the same speed?
I had a buddy with the drill press that had the symptoms and it turned out to be a broken key on the shaft.
A_Pmech
IL
The usual culprit on those is either a loose set screw on the spindle drive pulley or a slipping belt. Oftentimes they don't have a key between the pulley and the spindle drive slip sleeve.
C
Concrete B
The motor and belts are good. It sounds as if it is running fine but the bit stops turning when it hits the workpiece. I'm not sure how to access the shaft to check set screws, but I'll have another look
rlitman
Long Island
I had a similar issue with an Atlas drill press.
The quill has a splined shaft that turns the chuck. There was a delrin (plastic) piece connecting the splined shaft to the pulley shaft, and an ear of it broke off. It was maybe a $20 part, and relatively easy to replace.
