Points grease
elderstarr
For ignition points? They should. Just go to an old guy to ask cause I doubt any teenager would know what you were talking about.
jvitez
Big Sky Country, Canada
I guess that means I'm in the brotherhood of geezers, when I know exactly what the OP is talking about. Porschedude996TT: unless your post was in jest, you must be a young whipper-snapper.....:)
Sorry johninct, no idea.
porschedude996TT
Santa Maria, California
Dooh! I get it now, yes, thanks MAD!
jvitez, nope, not that young any more (57) and I have no excuse. I changed out a set of points for a pertronix a couple of weeks ago on my sons VW Bug and my older Porsche some months ago. The wording hit me strangely.
smothers33
I could be wrong but can't you use dielectric grease. Is that what your talking about?
e30bradley
Don’t have a garage in Arizona USA
Use this if you willing to pay.. I've seen people use a drop of motor oil. I've used dielectric grease and had no problems but it comes off from the heat.http://www.pelicanparts.com/cgi-bin...ription=Bosch Distributor Grease, 225 ml tube
I think you can really use anything.. PB blaster, 3in1 oil, phill wood oil, motor oil, ATF, lithium grease. or anything else. WD-40 will evaporate and heavy grease will sling off.
Bruce Lancaster
Standard lubricam, SL-2. If anyone needs it their dielectric grease is SL-4...can't have too many numbers for modern times, with clerks whose grandfathers never saw a point.
NAPA Echlin Moly Lubricant for points, ML-1
Buy several...it's just gonna get harder. Even though one tube will probably serve me for the next 3 lifetimes or so, I keep'em stashed for the day I step on my supply or the beagle eats it all...
mvptrukin
Denver, CO
I remember when Bosch use to include a little with each set of pts. A tune down use to include R&R the dis put it on the Sun dis machine and set the dwell, check the advance then put a tab on the rubbing block. How many shops still have a dis machine?
RM209
MD
Recently I picked up an NOS set of older Proto ignition wrenches in a tool roll, and it included a small tube of Sorensen brand ignition distributor lube.
RM209
