My compressor got high today . . .
Steevo
43.49600, -112.04300
I finally raised my compressor up onto the pallet rack today.
First I made some cross-mounts that drop into the pallet rack.
I used 4” c-channel and ¼” x 4” flat bar to make drop-center mounts that place the compressor lower between the load beams for a little more clearance when installing it, and for stability.
Then I used rubber isolation mounts between the feet and the mounts:
Then I arranged it so that my little forklift could get it into place, removed the front load beam so I could get it situated, and held there while I reinstalled the front load beam.
Once the load beam was in place, I lowered the lift forks out from under it.
This setup gives me more room underneath for my blast cabinet. Yeah, that beam is higher on one end. I fixed it after I took that picture.:
While I was at it, I plumbed in a high-side gauge and hose quick-connect ahead of the regulator. I picked up the large gauge at a surplus place for $10.
A_Pmech
IL
Looks good, nice work on the special drop center beams.
The only thing I might add if I was doing it is to install some clips on your beams so that the pallet rack beams can't spread and drop the compressor. Your rack beams may not require it, but some pallet rack systems need cross-ties between the beams to keep them from spreading at rated load.
Regardless, it's a heck of a way to save space and looks very clean. It's nice to have a forklift! :D
Morrisman
Angeles City, Philippines
Funnily enough, while I was trying to re-arrange stuff to make more room (physically impossible) I thought about the same thing: lift the compressor up higher so I could use the space under it. I can't stack on top of it, so raising it a yard or two would be a good move.
Just a thought, I don't have a forklift, so I'll have to do some creative thinking. :Homer:
Slick111
Everett Wa
Maybe you will need to run a bigger drive pulley to speed up the pump cuz now your compressor is up in altitude hence thinner air. Yuk yuk
NUTTSGT
Northern Central Ohio
I like the way you plumbed the cross with the guage and quick connect. You do nothing light duty, everything is industrial in your shop.
jamesemery728
That looks great. Very good way to make more space where you need it. How about some info and pics on your forklift. Looks like an excellent size for a home shop. Thanks
bluevenom867
St.Petersburg,FL
Looks like a IR T30 compressor? Those rubber isolators have a solid core or does the bolt go through them? Wheres the tank gunna drain to now that its over your blast cabinet?
Steevo
. . . How about some info and pics on your forklift. Looks like an excellent size for a home shop. Thanks
That is my Clark walk-behind electric forklift.
It is a handy little unit. I think it can lift 3000#.
My brother-in-law gave it to me. One of his customers was going to scrap it when they got a new one.
I have used it for hanging cabinets, for dropping the toolboxes into my steel workbench frame, for loading and unloading tractors, parts, a lathe, a mill, etc.
Steevo
That is an IR T-30 with 2475 pump and 5HP Baldor motor. The rubber mounts have a solid rubber core, rated at 175# per mount. It dances on them slightly when running.
I plan to get an automatic drain, and run a rubber hose from it to a location near the floor by the roll-up door.
jamesemery728
Very nice, Thank you.
OccupantRJ
Eastern North Carolina
I have always heard them called walkie stackers, or walker stackers, and have used them many times when I was a millwright for setting equipment inside industrial spaces. Fantastic little machines.
