What Kind of Hammer is This?
sometoyotaguy
Southern Maine
It's like a small sledge, but I don't know what it was originally for.
Bruce Lancaster
For Zombies. Big side for quick sudden reaction, pointy side gives less spatter when you have a second or so for precision aim.
5lima30
Mountains of Western NC
Old cedar shake/ shingle hatchet would be my guess. BTW, a oval handle hole is generally means it was machine made vs. a blacksmith made implement which will have a retangular handle hole. JMHO.
GeorgiaHybrid
Extreme NW Georgia
A shingle froe doesn't come close to looking like that. I think it might be used for splitting kindling but not making shingles.
Captain-Matt
Could be a blacksmiths hot cut chisel.
The smith would hold the workpiece, and the handle of this tool, with the bladed end on the desired cutting place, and a striker would hit the flat end.
lbgradwell
Oakville, ON
I'm inclined to think it's for kindling too.
I don't know much about blacksmithing, but I would not have expected so slender and sharp an edge for working metal...
:+1:
here is a Froe (granted its a small one, about 8" blade 10" handle), and they were also used for splitting out raw stock and making things that exactly matched the grain. Used to be they would split handles out of hickory, then shave split them to rough shape before final shaping. (I wish I had a source for hickory myself... good handles are getting harder and harder to find...)
Note the hole is round? Smiths don't have a problem making any shape eye they desire, for example, the classic hatchet head tear drop eye was originally an easy shape for them to deal with...:
I don't think so for two reasons: The mass of the head would reduce the impact of the blow, and the head itself is not mushroomed at all, so if it was for that it was rarely/never used.
I have a couple of splitting hatchets. thick steep angle like a splitting wedge, that one is different, but it still widens out for good splitting.
Captain-Matt
A fair point about the mushrooming. I can't work out the scale of this thing, it could be for marking out decorative lines, but again shows little usage.
I work for a blacksmiths, so I've seen a load of the stuff we have that could be similar to this.
Either that or its simpley a cross-pein hammer with the pein vertical instead of horizontal.
OP, a pic of it next to a ruler perhaps? :)
rsanter
visalia ca
Home defense hammer.
You decide wether you want to split their skull or just knock them out for the police to deal with
Bob
bgott
Houston, TX.
It's a blacksmith's hot cut chisel, as has been mentioned. It's not a hammer, you set the chisel on the red hot metal and then you beat on the other end with a hammer.
Sounds like you need three hands to accomplish this. The Hardy hole Hot Chisel makes far more sense...
Bruce Lancaster
Not Three hands, an apprentice! Often a very large part of the work was based on apprentice muscle, not just three handed jobs. Blacksmith could direct heavy hammering by smacking the right place with his own hammer, then the apprentice pounded hell out of that place until blacksmith hit another spot.
Apprentice was practically a slave during his term in early days...his pay was learning a job that would support him a few years down the road when his apprenticeship ended.
Cutting metal was a big deal with lots of techniques before there were hacksaws, oxygenated torches, powered tools, etc.
bgott
Houston, TX.
How often would such a thing need to be sharpened?
Not often, as long as you don't drive it into the hardened surface of the anvil. The chisel is high carbon hardened steel and the material to be cut is pretty soft at a red hot heat. If you look at a lot of well used wrought iron anvils the horn and the flat spot between the horn and the hardened steel plate on top of the anvil is seriously cut up from hot cutting. The wrought iron is pretty soft. If I use my hot cut set tool instead of my hot cut hardy I lay a piece of channel iron on top of the anvil to protect both the tool and the top plate.
