Question -
I've got 2 units and noticed tonight, while the downstairs unit cycled on, the air was warm. And got warmer. Didn't get cold quickly. Ran outside and saw the blower/fan motor on top was not turning.
Quickly ran inside, turned the unit off with the T-stat. Went outside, spun the motor by hand, it is smooth. No roughness or binding.
Go inside, flip the unit on with the T-stat, motor outside turns on and runs fine. Inside temps coming out of the duct are around 45F, inside temps around 75F and outside around 70F. Same for the upstairs unit, so the downstairs unit seems to be OK even after running with no blower for 3 mins or so.
I'm new to electrical. Don't know anything save for doing basic wiring and even then I have to follow books step by step.
From research I've done it is either the motor itself, which I've found online for around $120 from Grainger, or possibly a capacitor. Not knowing anything about capacitors, how would I test it? And would it make the motor run intermittently? If I replace the blower fan motor, does the new blower fan come with the new capacitors required? Or should/must I buy new ones as well?
Here is my blower motor, part # GE 5KCP39BGS162S, I believe this is a drop in replacement for it.
http://www.grainger.com/Grainger/GENTEQ-Condenser-Fan-Motor-6DLL8
I want to fix whatever the issue is, money is no issue at this point, because if the unit overheats we are screwed, it will damage the a/c unit. I'm OK replacing the motor and capacitors just need to know what to buy.
