My goal is this: Setup garage compressed air system properly so that I can use my HF sandblast cabinet with out trouble. I attempted to use my current craftsman 33gal 5HP oilless it has a cfm of close to 6 at 90psi. Looking over instruction manual The cabinet needs somthing like 10cfm at 90 to properly run. I also had problems with moisture I however was running straight from my hose.....
I want to properly set up my garage to use compressed air not only for the blast cabinet but for other tools aswell.
Heres what I have so far...
Johnson Controls A-4412-2 Refrigerated Air Dryer.
http://cgproducts.johnsoncontrols.com/CAT_PDF/1921105.PDF
Please look at the specs and let me know what you think.
I also have an Ingersoll-Rand EDV-2000 Automatic Drain Valve.
I want to purchase a nice 60 Gallon compressor that can adequately power my blast cabinet and I hope after you look at the specs of my air dryer you may be able to suggest a compressor that would work well with my dryer unit. I still have to buy airfilter / regulator and coalescent filter and moisture trap. Any thoughts would be greatly appreciated
