ezridr60
I've got a garage built into a hillside, cars are parked on the lower level which is mostly below grade. The upper level houses my woodshop. During the transition from winter to summer as the ground thaws there is a lot of moisture and high humidity within the garage area. I'm assuming the walls, and quite possibly the floor need to be sealed to prevent moisture ingress. the question therefore is what products has anyone used that have worked well. The garage has a heater, but I use it only if I have work to do on the truck, so it's infrequently used. I'd eventually like to paint the walls, but without a sealer I'm afraid the moisture would just peel the paint. Ideas appreciated.
