RalloZ35
There probably a thread on this but I just got anxious to pull apart my first ratchet.. so now I want to oil it or grease it.. should I use oil or grease? Thanks, Austin.
x2You are probably gonna hear all kinds of answers but sealed rat I'd use grease,non sealed probably oil.But that's just my. 02¢
A flat, thin piece of metal or plastic will work just as well as the tool. Thick paper may even do the trick.
I use a light oil (like 3-In-1, 20W) or plain 5W30 on finer toothed ratchets, particularly round heads, and a heavier oil (75W90 gear oil) on the older really coarse ratchets with loose tolerances and more of a tendency for the oil to seep out.
As fondly as it's spoken of here I'm not sure it isn't a bit overrated, but one thing I do like about lubing ratchets is getting a good bit of lubricant into the reverse mechanism, which makes the reverse lever easier to switch and can prevent it from jamming up.
just for informational purposes... 75w90 gear oil is the same viscosity (or near enough) as 5w30 motor oil. gear oil and motor oil use two different scales for their weights, but when measured in a common unit (cSt), they're almost identical. lots of different properties, but viscosity isn't really one of them.
ahm
Does anyone have a part number for the Matco and Snap on tools mentioned above.
I see a problem here.I use a light oil (like 3-In-1, 20W) or plain 5W30 on finer toothed ratchets, particularly round heads, and a heavier oil (75W90 gear oil) on the older really coarse ratchets with loose tolerances and more of a tendency for the oil to seep out.
While RLL (the "Red Lube of Love" - don't ask, just blame Merk) can work wonders for medium and coarse toothed ratchets (not so good for ultra fine ones), it has one major annoying (IMHO) feature - it bleeds. AND bleeds, and bleeds, and bleeds, and bleeds, and bleeds...... I hit a few of mine with the stuff years ago, and I STILL wipe up/off RLL from the ratchets, from where they rest in the drawer, from whatever they might have sat against in the drawer.... The stuff is relentless. I've been using 3-in-one oil in almost all the ratchets I've cleaned up in the ratchet obsess.... er, collection so far. Then again, most of those ratchets no longer see daily use, so a relentless bleeding lube like RLL might better suit you, provided you don't mind the mess. My tools see a variety of uses often not under the hood, so oily/greasy tools lying in oily/grimy drawers are unacceptable to me. YMMV
I put oil in mine.. its unsealed, but grease made it function wierd.. Gear oil smoothed it out some and I like it now.. Tool box is probs filled cause I did 2 ratchets with it![]()
Phil Wood tenacious oil. Like gear oil, but WITHOUT the smell.
Can...can you use it in differentials???Phil Wood tenacious oil. Like gear oil, but WITHOUT the smell.
Its an allen ratchet. Its fine now, I may try grease again
Lost the ball... now im really pissed
