jskeen
Ok, I've got a problem that I can't find an answer to using the search tool, so I thought I'd toss it in here and see if it floated.
I requested my dad to activate the geezer tool acquisition network a while back and find me a decent bench vise, since the 7 inch leg vise was kinda in an awkward location back by the forge, and the little wilton tradesman I had inherited from my granddad would not stand up to the kind of banging I needed to do. There ensued much grumbling and grunting, and muttered threats of sending me chiropractors bills, but eventually he duly produced the pictured 6-80 model 4 inch bullet. Great, no cracks, reasonably well treated, and all that, but there was a bit of a problem with the lead screw and collar. No matter how clean and lubricated I got it, and how carefully I tried to dress the bottom of the retainer ring socket, as soon as I tightened the screws down, the lead screw bound up and refused to turn. After much wailing and gnashing of teeth I finally just snugged the screws up enough that the collar was snug and the screw turned with a tolerable level of drag. Not the correct solution, but it worked for the time being. After a couple of years took down the forge, rearanged the shop and eliminated the countertop with the 12 inch square hole that the baseplate for the vise, the grinder/buffer and a couple of other assorted tools swapped in and out of. So, it sat on a shelf under the radial arm saw and (without my knowledge) grew a moderate coat of surface rust. Argh.
So, now I've reconfigured the shop again to accommodate my "new" 1954 dewalt radial arm saw, and decided to inlet a home for the vise again. But, I thought I'd see about fixing that annoying bind in the lead screw collar.
So....... After looking at all the 400s's I could find online (most of which were here, oddly enough) I decided that something fishy was going on with the retaining ring on mine. (sorry for the crappy pics, but the wife has the good camera again)
Anybody recognize the configuration of this one, and have suggestions on how to either fix it, or replace it with the correct hardware?
Thanks
James
Thanks
James
