964haus
I've begun my shed build which I'll post up in a new thread in the future. I'm in the process of ordering materials and I have a question regarding the framing of the roof.
The shed will include a shed dormer for aesthetic purposes and to allow some additional light in. I was originally planning on 2x4 framing for the roof, but have been waffling on perhaps using 2x6 instead. Right now, I'm planning on 16" spacing, but again, wondering about 24" spacing. The shed will be insulated and I understand that 16" spacing is easier to insulate. (I think I read that....)
So my question - do you think 2x4 roof framing is sufficient? or should I be using 2x6 to make it the strongest shed possible? I am in the pacific northwest, so no real snowloads to consider and it's in an urban setting, so minimal wind issues. Roof pitch is 8/12. I plan on using collar ties at 2/3 up to tie rafters together to maximize headroom.
Thanks everyone - I'm new at this, so really appreciate the help....
Matthew.
For reference, here's the Sketchup model that I've created to help visualize it
Matthew.
Im going to start a thread up with my build. The back of the shed where you see the two big openings, are both doors. One opening will be the standard barn doors and the second door opening (the bump out) will have a hidden door. The wall will be the door so it doesnt look like a wall of doors. Atleast that is the plan if i can engineer the door right
I see your in canada, i assume you get alot of snow? if so i would just go with 2x6's 16" on center to be safe. Unless you go to HD and order some custom trusses ($$$$$) in the grand scheme of things its really not that much more, i think it worked out to be $70 bucks more for the 6's rather then the 4s. We also did 3/4 sheething on the roof not only to help span the thickness of the T&G boards but we have trees and they do drop limbs and. I just dont want a branch to go through my roof, and if one does at least i can say i tried to prevent it
