Sealing "butcher block" top?
1AB JAG
Beervana aka Portland, OR
Hi all, my new work bench has a maple "butcher block" top. It came unfinished so I'm trying to decide what would be the best finish for it. It's going to see light duty as I have a work table that gets most of the heavy work. I am considering; tung oil or polyurethane. Anything else I should be thinking about?
Cheers,
JAG
bhalv
Boise Idaho
I just used spar varnish to finish the top of mine, solid hard finish, easy to clean ans rated for outdoor use. sorry but don't have any pictures i can upload, have one i can text you if your interested.
1AB JAG
Good suggestion! I had forgotten about spar varnish, I still have a can left over from another project too.
Thanks!
Jim B
California, USA
I picked up a Lista bench with a "butcher block" top on the cheap and finished it with gloss waterbased Varathane. Put on a coat and let it dry 2 hours. Sand with 220 grit and put on 2 more coats and go have a beer. I have a similar table at work I use for a desk that I finished this way and it sees all kinds of abuse (assembling parts, spilling my lunch, etc) and it's looks great after 3 years.
Jim B
California, USA
My work bench was only 13 bucks but what I really want to know is how do those wood workers keep from spilling their lunch??:lol:
Rusty Musket
Whatever you use, be sure to seal the underside and endgrain as well. If you only seal the top, you risk moisture intrusion into the bottom from humidity and you will end up with a nicely curved top.
I use mineral oil for food prep surfaces. It is easy to apply, cheap and odorless. However, non-drying oils basically protect wood by filling its pores and thus preventing moisture and other substances from getting into the wood. These finishes should be renewed often to keep the wood saturated otherwise you are very likely to stain the benchtop with glue, blood, oil, grease, coffee, and anything else you manage to get on it.
Drying top-coat finishes protect the wood by forming a hard protective layer on top of the wood's surface. Many of these finishes are also resistant to chemicals, acids, and UV rays (i.e. spar varnish). Hard finishes hold up well to abrasion but can be compromised if you cut through them with something sharp. If you can afford the drying time, and have plenty of ventilation, Spar varnish is not a bad choice. I would go with a satin finish because you do not want your bench constantly reflecting light into your eyes like you would get with a high-gloss finish. Just let the top get scratched up for a few years until it bothers you. Then sand out the scratches and add another coat.
Vvmvbb
CT
Waterlox or Watco.
Or old school: linseed oil cut with turpentine.
Tarnished
SW Ohio
Plane ole Shellac works well for me. Easy on, and east to remove (with alcohol) if needed. I use amber shellac because I like the color, but you may like clear better. 3 cotes and good to go. Holds up well, and easy to touch up if needed.
pipsters
USA
Here is 3 coats of Watco butcher block oil, I posted it on Amazon for the same product.
Came out good seems to be fairly durable.
BWS
Mnts of Va
Not really a suggestion....just sayin what I'd do.
Would mix up a batch of EA-40 Smooth-on epoxy and squeegee it on with a new bondo spreader.
matty d
Yolo County, California
Where do you get a reasonably priced/ cheap butcher block top? How did you get yours? Is it possible to get this cheaper than lets say, IKEA prices? Im looking to top off my toolchest cabinets. Thanks.
coolreed
Oklahoma City, It's a Windy Heat.
Tung Oil works very well. If you scratch your butcher block you just touch it up with more Tung Oil. However, you have to use several coats in the beginning depending on how much gloss you like.
My 2 cents. Good Luck
At Ease. Carry On.
