The start of my 30x48
NXGTS
Indiana
First and foremost I would like to thank Ryan and crew for this fantastic forum for all of us to use as a resource. It is one of the best on the web. I was introduced to this web site through a fellow Mustanger when he posted about his new garage floor (Wolverine) on the Mustang site I used to frequent. I now mostly come here when I am in need of any resources or just a good laugh.
Now for the garage. It is a 30x48 with 10'8" side walls on the interior. It is somewhat inspired by a couple of member's garages on this forum. It is a cross between Brassspike and Porschedudes garage. Half will be attic storage trusses and half scissor trusses. I need the extra room for a lift because I cannot have taller sidewalls because of my neighborhood association. With my budget I will be doing most of the work myself with family and friends except for the foundation. My concrete guy works alone I am getting to do a lot of helping with it as well. I will update as often as I can but I imagine this will take most of the summer to complete.
Here are some pictures of what has been happening the last couple of weeks when the weather will allow. It is spring in Indiana after all.
[/IMG]
[/IMG]Just a cool pic of the new driveway going in.
[/IMG]The son trying to figure out how to operate the trencher.
[/IMG]
[/IMG]A pic of my ugly mug after a long day of hand digging a lot of dirt/clay
ejm1961Tbird
Knoxville, TN
Good luck with your build! I liked the brassspike garage too. I want to make a 30x48 too, but mine is still in the dreaming/planning stage. Keep us posted on your progress!
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I see some grass inside of the foundation, I hope you remove it all along with the roots. If not it will decompose, and you'll end up with hollow spots under your concrete
On the other hand, I wish HOA would lighten up on some building restrictions. It seems most people always build to what looks good in a neighborhood, but then an HOA steps in and then dictates that your roof can only be so tall, your walls only so tall, and other such nonsense. Most of those that dictate could probably care less about a garage anyways.
A few years back on the next road over, out in the country they started building new houses. One guy that I worked with bought one but there was an HOA. He wanted to add onto his garage as the HOA didn't want sheds out back. They would not let him add on to the existing garage because they thought it would take away from the looks of the house. It wasn't going to be a huge garage, it was going to be the same roofline, same brick exterior, just a little wider. Nope, no way!!!! He found a loophole. He built the garage on the other end of the house. :spit: Two driveways, two garage doors. It actually looked pretty bad, but he got the storage he wanted. I think that kind of broke the HOA after that. The row of houses down through there have a different styles of garages now. One has a pole barn that literally uses up all of his back yard, an other had a pole barn in the front yard. I find it all rather amusing :bounce:
N
NXGTS
Indiana
All the concrete is in. Lumber was delivered last night at 2230. My neighbors were not pleased. Menards should know better than to deliver that late. It ended up being a fairly unsafe operation that got the police called. I don't know who called them but it may have been the driver of the car that almost ran into the trailer that was parked in the road. Oops!
Yes, the rest of the sod was scraped off after I trenched the water lines into the building.
jeepntxj
Looks like it'll be an awesome shop. Keep up with the updates!
Oh, and BTW... I just happen to be wearing the same shirt right now that you have on in the first pics. Kinda odd...
brassspike
South Mills North Carolina
Just foud your thread. Looks GREAT! When I built here there was nothing around. Now houses with HOA.....but I'm not a part of it and do as I please! I've got this post on notification!:thumbup:
N
NXGTS
Indiana
[/IMG]
The framing is most of the way done. The trusses were delivered today. We will be installing the trusses this Saturday (weather permitting).
[/IMG]
This gives you an idea of lot placement. I'm not a huge fan of having two driveways but the building codes have changed since we built the house. This is the only place the garage could go without a variance. I can't wait until the weekend to get this thing well under way.
N
NXGTS
Indiana
We only had a couple of rain delays. Not to bad it was cloudy most of the day. With the help of some awesome family and friends we were able to get all the trusses up except the last end truss which I need to work on anyway.
Not a great idea for me to ride the pallet but my legs were worn out from all the days climbing. We just needed to get some final bracing on in case of storms. Hopefully I will be able to get most of the sheathing on before I have to go back to work on Thursday.
marc@kentucky
Subscribed to this thread-
NXGTS, I am just getting started on a very similar building to yours, albeit in a 48 wide X 32 deep configuration. I am also doing 10" walls on block foundation and scissor trusses on the right half of the building for a lift, with storage trusses on the left hand side.
I look forward to following along with your build and I plan on starting a build thread of my own once it quits raining long enough to see some real progress.
I am a fellow "Mustanger" as well having rebuilt around 20 dating back to my pre-teen years. My '65 fastback and 2007 GT-500 will immediately be going in the left hand side of the building, and I have a few projects in the wings for the "shop" side as well.
I did get the footers poured the week before last, so here's a little sneak peak- don't want to muddy up your thread..
Again- excellent work so far, look forward to following!
Regards,
-Marc
Western KY
N
NXGTS
Indiana
I was able to get this side of the roof on over the last couple of days.
Here is a view from the back of the building looking forward. Not the greatest pick but you get the idea. I still have some sheating to do. It seams as if it won't ever be done.
So far it has been a lot of work but looking at it I have had a lot of fun as well.
NUTTSGT
Northern Central Ohio
It looks like the start to a great build. I can only imagine the frustration of all the rain this Spring and trying to get it started.
N
NXGTS
Indiana
This weekends project was the dreaded stairway. This was very intimidating but once I started it went really well. I started with the landing and did the lower stairs then started the upper. It was not nearly as bad as everyone I talked to said it would be. I need to do a little tweaking on the upper set before I put the treads on. Here is how it sits now. Excuse the really large mess I have made of the situation. I need some organizational skills.
As you can see there is a lot left to do. Brick, siding, soffit on the outside. Finishing the stairs, framing the bathroom walls, plumbing, and electrical on the inside. All that will keep me busy until the fall.
N
NXGTS
Indiana
So today was a good day. I was able to get a small corner of the garage cleaned up enough to get one of the toys in. My '89 Wagoneer that has been in storage since last October. It's good to have it home.
Progress on the garage hasn't been smoking hot but it has been moving. The siding and gutters should be done very soon. Then attention can be put on the interior. I'm really happy with how the brick turned out. What do you all think?
N
NXGTS
Indiana
I'll try to post up some pictures tomorrow. They don't show a lot of progress. The outside is all wrapped up. The interior framing is finally done. The plumbing rough in is finished. I did get the plumbing and framing inspected a couple of weeks ago. They passed with flying colors.
I have started the rough in for electric. I have two of the 12 circuits complete. That is the goal over the next couple of days is to finish the rough in and get it inspected. I have an HD-9XW coming that should arrive Nov. 3-4th. Then the drywall and the rest of the insulation will be delivered Nov. 7th.
Progress has been very slow over the last month because I have been at work for the last 3 weeks straight. The goal is to have paint on the walls and all inspections done before Christmas.
N
NXGTS
Indiana
This is the second floor which will be just for storage. It is 23' long and 12' wide.
Looking from the back to the front.
And front to back. I know the stairway location really hurts floor space but it was the only way I could get scissor trusses and attic storage trusses in the plan. I figured that corner was already shot because of the bathroom.
Last but not least the exterior. Fairly boring but it's finally done. Graded and seeded. Now all it needs is some landscaping. Maybe in the spring.
vectorw8015
USA
Now that you have finished the outside, could you please come to my home and build one about the same size? Looks great, I hope you are enjoying it!
westray
Nice build and love the size and space that you will have. I really like the layout of your building.
N
NXGTS
Indiana
Thanks for all the kind comments guys. It's been a long process and I do appreciate the positive feedback!
Vectorw8015, I won't be building anymore buildings in the near future. They say to build the largest building you can afford to build. If I would have had someone build it for me I would only have half the building. To get what I wanted I had to do it myself. I guess you could say it was out of necessity.
N
NXGTS
Indiana
It's been a couple months so I thought I would update. The goal of paint by Christmas did not happen. I got into December and the holidays just kinda took over. It went pretty well untouched for a month. The electric rough in was done and inspected in November. I did most of the insulation(R30 ceiling R13 and some R15 in the walls) in late November. Finished the insulation about a week ago. I rented a scissor lift to help hang the drywall and finish the insulation. I had grand plans to finish the whole ceiling in the week that I had the lift. That didn't happen either but I worked my tail off anyway to get the very highest part of the peak finished. That scissor lift was real handy. In fact I am so spoiled I am going to rent it again for paint, hanging the ceiling fan, and light fixtures.
[/IMG]
Then there is the new addition to the shop. That is if you can even call it a shop yet. The 9XW Bendpak. While it makes no sense to install a lift at this point. The lift was in the budget for part of the build process. Since my budgeting skills are not great I thought it would be a good idea to get the lift now before I run out of available funds. It has been great for one thing. It is a fantastic catch all for tools and everything else that I'm to lazy to put away. I need to spend an entire day straightening up and cleaning before I go any further. The remainder of the drywall is for the foot or so that needs done on the two sidewalls and the inside of the bathroom.
[/IMG]
N
NXGTS
Indiana
I thought I would give a little update. I am nearing being finished. Only a few more things need to be completed. The bathroom is not done yet. I spent the last 2 days cleaning and was able to FINALLY move in. The Mustang is in it's new home at last. The lift got to lift a car for the first time instead of me. It was handy to finish the drywall and hang light fixtures with.
I do have to say the project is really starting to drag on now. We're going on a year and and quarter. I guess that's the nature of DIY. It is starting to take it's toll on the family life though. The wife is constantly on me about being out in the garage all the time. I think we just need a vacation.
Everything is not yet in it's place but this should give you an idea of where I'm headed with this very long project.
It's a relief to be able to walk out to the garage and flip a switch to turn on the lights. No more flashlights to find your way to a construction halogen light. I was grinning ear to ear while texting everyone I know when I got the Stang on the lift.
N
NXGTS
Indiana
Thanks guys! I was once a diehard Ford guy. As you can see I grow wiser as I age;) The stripe was actually color matched to the lift. The lower part of the wall (the block) will be painted with a gray masonry paint too. I just have not gotten around to that yet.
That Mustang has been with me through thick and thin though. I purchased it in '96 after getting back from cruise, when I was in the Navy. I don't think there is a nut or bolt on it that I haven't touched. It's sporting a stroked Windsor and a C4 currently. The day I moved it to the garage is the first time it had been fired up for almost 3 years.
NUTTSGT
Of course you're wiser, you kept the Mustang all these years. :D
BTW, have you hit up the military thread in my sig ?
N
NXGTS
Indiana
Thanks Tbird. It's like a breath of fresh are to finally see light at the end of the tunnel.
Nutts- I am on the military thread. Post #6. It was a long time ago!
UN4GTBL- Thanks for the compliment.
mdkingsley
Chickamauga Ga
Hot rod Mustang not fired up in 3 years? Shame on you for that. Get it out and drive the snot out of it. Very nice garage good use of the space and well thought out it appears.
Medeek
Copalis Beach, WA
Really nice job on your garage, congrats. The stairs does cut up the space a bit but overall I think it works, it adds a certain character to the garage IMO.
Do you have any recent pictures of the upstairs storage space, I would love to see how that worked out. Did you put a door at the top of the stairwell or leave it open?
