chris142
went to use my Air tools and I have a hole in my airtank.rust I assume. odd cause I always drain it after I use it.now what do I do? have it plated or throw it away?
.....personally, I'd scrap it simply b/c if one part is rusted, the rest may not be far behind.I didn't intend to open up a can of worms, I'm just saying what they do on cryo tanks. personally I'd scrap it due to the fact that its probably thin steel and chances are its rusted beyond repair. If it rusted from the inside out, i'd scrap it. But i was saying if money's tight and and it rusted from the outside in and the inside is clean i'd patch it. really no way of knowing tho.
oh and cryo tanks are like 1 inch thick steel so they can accept a patch if its a small problem where compressor tanks are a fraction of that.
All of this technobabble comes into play when the improperly repaired tank blows apart & your widow sues the manufacturer (unsuccessfully).
Get a new one.
CJK
National Board Certified Pressure Vessel Inspector (Pennsylvania)
AWS Certified Welding Inspector
It's rusted from the inside out. The drain is not at the lowest point of the tank so I would move it up and down with the drain valve open to help remove the water.
Part of me wants to cut it out and patch it. I know several professional welders so getting a good weld is not the problem. Another idea is to buy the 60 gallon tank on Craigs ($75) and put my pump and motor on that.
Bummer cause I just "tuned" it up with a new belt, filters, oil etc. I hate to throw out the motor and cast iron pump![]()
I'd like to see some pics of exploding air compressors that are designed for home use with a 175 PSI max pressure.
Build a BBQ! Air tanks are easy enough to come by.
Always something...
where do I find a new tank?
Everyone talks about how ones life is in danger if it is repaired but has anyone ever actually saw one that exploded. My cousin fixed one, I welded a patch on one, and I have known a couple of others that have been repaired.
The OP's tank just started leaking when it went bad and had thin metal. What's going to cause it to explode all of a sudden when it didn't explode before. Usually when they go, they leak.
Google is your friend, and there have been quite a few documented or re-documented right here on GJ. This is NOT a thing to start the "prove it" mantra on.![]()
Yea I would just buy another tank thats a Manchester brand or what not. The big thing is when you invest in a new tank, you want to make sure you drain it all the time. The outside maybe painted but most likely the inside is raw steel or light primer at best.
Understandable. I'm all for safety. I'm also for facts. Everyone TALKS about how unsafe it is with no first hand experience. I'd just like to see where a tank exploded from being repaired. If a little research was done, you would find that an air compressor that explodes is not caused by a repair, but is caused by either over pressurizing the tank, or by a buildup of oil vapor inside the tank. Also if a tank does explode, it will not send shrapnel flying, the tank will rip apart. If you alter the tank by going past the recommended pressure, removing the relief valve, then yea, you are asking for trouble. I know more people that have repaired tanks firsthand with no trouble and have went on to use them for years. I have yet to see an exploded tank or even know anyone that has seen an exploded tank. Sure, anyone can say that they know someone who knows someone that was related to someone that heard someone had one explode because someone welded it.![]()
I have the same setup on my large compressor. I recently installed an automatic drain on my small compressor and have been really happy with it.Agree there. The little petcock valve is a pain in **** under a big compressor to drain every day.
I "borrowed" this idea from members here just today:
Wow it was nice when I left today..just flip the handle on the ball valve and walk away!
