How do you Keep your tools clean
anaxagoras
CT
I'm just wondering what everyone else does to keep all their tools clean between uses.
Wipe 'em down? Throw 'em in the parts washer? Brake cleaner? etc.
MarkH
Kansas
You mean you are using them!!
You put them in an expensive box and look at them. Then you do not need to clean them.
Polish yes, clean no.
Never did anything more than use a rag to rub the obvious chunks that could hurt another job off. The tools have survived since my grandfather bought them.
speed bump
Butte Montana
Generally I just wipe them down with a rag but if they are really dirty I grab the nearest can of solvent/cleaner and use that.
Steve_S
So Cal
I wipe them with a terry rag and if necessary, a bit of simple green. They don't go into the box unless they are 100% dry. Nothing dirty ever goes into the box.
Danglerb
SoCal
Wipe them down with a shop towel.
I put out a throw away plastic tray and let oil bottles drain into it, or sometimes to soak stuff in Marvel Mystery oil since I like the wintergreen smell.
Clean tools is great gag at the shop where my car is right now, I'll pick up a wrench and give it a hard look then ask the mechanic where he keeps his Snapon Wrench Wax.
Uncle Buck
Kansas
Not much normally. If they are really dirty I wipe the worst off with a rag. If they are flat out filthy I will use anything that will cut the grease that is readily available, Gas, Brake Clean, any solvent based product plus WD-40. Whatever is closest at the time gets used and I never swab, caress, or pick small bits and pieces from little grooves or lettering and the like. More of a lick and a promise guy myself!
Danglerb
SoCal
I do use simple green sometimes, but make sure some kind of oil goes on before I put it away. Most of the time I have a shop towel around that is PLENTY oily, but not filthy dirty.
I'm hooked on blue nitrile gloves, but critters live in my cars.
Merkava_4
Clovis, CA.
I don't use shop towels because I don't want that red lint on my tools; I use white Viva paper towels or cotton baby diaper clothes.
nissan_crawler
Wichita, KS
:wtf:
If mine are dirty, they get wiped off with IPA, otherwise they go in the box as is. I'm like hholmberg, I'm not picking out the details.
dxdexter
I throw them all in a my cart until the job is finished and them I wipe them with a rag and put them in my box.
Junkman
Northeastern CT
Over 50 years ago, a fellow that was my age now, said to me, that you can tell the quality of a shop and the mechanics by the way they keep the floor clean, and the tools clean and put away in there proper place. He also said that a good mechanics tools could be wiped across a white cotton shirt, and not leave a mark. I have always remembered that, and even though my shop floor is not cuttered with debris from a car that I am working on, and the tools are oily and dirty, when I am finished with the job, I will clean all the tools, put them all back into the boxes, and then sweep the floor. My garage is filled with lots of clutter, in an organized way. I know where everything is, and that is what is important. What I really need is a bigger shop, and less in it...... :lol_hitti
Moose-LandTran
The Brink of Insanity (England)
Won't WD-40 makes your tools greasy?.... or does it dry eventually
Nope, once you wipe it off it leave a very fine layer that's not greasy. I never wipe this fine layer off, as it serves to prevent rust. This is also why none of my tools have a spot of rust on them, even the ones three times me age.
Very true. I don't like working in a messy environment. Even if it's packed with stuff, i don't care so long as it aint messy. I'll be blitzing the stockroom at work soon..
Yeah, depending on the job, i sweep the floor a few times. Mostly because i'm working on the floor! In my toolbox, although it's small and packed full, everything has a place and i can always find what i'm looking for. If i'm working on a job for a few days, i put all the tools i'm using in a tote tray and they stay there overnight until the job is done. I've just ordered myself a toolbox, cart and of course a few tools to help with the organisation.
Fedwrench
Valley of the sun
Usually it's a wipe down with a rag sprayed with brake clean. Plier handles just a wipe down with a clean rag. Non chromed tools like impact sockets get a light coat of WD40 or smiliar lube after cleaning. Really dirty stuff goes for a bath in the Cuda followed by a wipe down.
Stanger
Alton, IL
When I'm finished for the day I clean my hands with waterless hand cleaner , dry them on a blue paper shop towel and then clean my tools with that. Works great for me.
rsanter
visalia ca
ratchets get a shot of brake kleen and wiped down
wrenches, sockets, extensions and similar stuff go to the parts washer
bob
russlaferrera
Central Virginia
I clean my hand tools with "Snap-On tool cleaner spray" , followed by a gentle wiping with a "Snap-On micro-fiber cloth" All tools are buffed to a high gloss with.... you guessed it "Snap-On tool wax and rust preventer."
Each tool is carefully placed in a "Snap-On tool storage sock."
stricht8
I noticed that most use WD40 or brake cleaner or some other organic solvent that gets readily absorbed through the skin with ill health effects that I would rather not care to experience. How about simple green or a citrus degreaser? I understand that these products might not cut it for heavy grease and grime. I feel that the nasty stuff should be used sparingly and with latex or vinyl or whatever gloves.
Merkava_4
Clovis, CA.
That's fine as long as you're willing to rinse it off with water. Those cleaners are very corrosive. Simple Green will remove the black oxide finish right off the tool if it's in contact too long; don't ask me how I know that. :(
