where's a good place to buy heavy duty casters for tool chest?
bimmerZ5
I'm looking to upgrade the casters on a CSPS 41" wide stainless steel tool chest. Would like to get something like 5"x2" swivel + lock that can do more than 500 lbs.
saw these on ebay, but not sure if they are any good?
http://www.ebay.com/itm/120915129735#ht_879wt_763
any advice?
EDIT: for anyone just reading the 1st post, i'm looking for these specifics:
5"x2" casters with swivel + double locking (locks wheels and swivel)
load capacity 500lbs or greater
1-3/4" x 2-7/8" hole pattern
alan camby
South of Indianapolis, Indiana
How much rolling around are you doing. Factory maintenace? or 15 foot from front of garage to rear?
Personally I have had good luck with Polyurethane wheels for a factory environment. In my last job i I pushed a toolbox over 500 feet everyday (I worked in maint). Poly wore well, are quiet, and handled chemicals and oils on the floor well. Never saw a maintenance guy put Phenolic wheels on a box.
OEXL16B
USA
Do yourself a favor and stay away from phenolic; it's too hard and brittle. Back in the old days, grocery carts used to have phenolic wheels; the asphalt would tear them up. If you notice, some of the newer grocery carts have the gray thermoplastic rubber wheels; they ride a lot smoother and are quieter.
t100
first, if you roll with your tool box a lot, then for the casters bigger is always better. having brakes is a plus, too.
try to find good brands like Colson, Albion, Wagner, etc.
I have Colson polyurethane casters on this little vintage roll cart. as you can see it holds 450lbs(9 x 50lb bag) of Thin-set mortar on it and I can roll it with ease.
bimmerZ5
this is more difficult than I thought... the hole pattern I need is 1-3/4" x 2-7/8" and I'm looking for 5"x2" casters that can take 500lbs or more.... all the heavy duty ones have the larger hole pattern...
Bandit01
I have a set of 5" casters I moved a yard barn with. 1500# rated each. 2 stationary, 2 casters. Did it great and I have not used them since. No damage at all except scuffed from pulling it down the street. PM me if interested.
tool_scrounge
Southern California
One option is to drill new holes in the bottom of the tool box. A stepped hole drill is perfect for this type of work. Just make sure there is no interference when the caster is swiveled before drilling the new holes - some older Craftsman tool boxes have metal hanging below the caster mounting surface and spacer blocks were required for caster locking brake clearance.
bimmerZ5
Thanks for the offer... but i'm looking for swivel double locking casters...
bimmerZ5
I considered that, but I'm not sure it's going to work. the larger hole pattern for the 4"x4-1/2" plate casters would either land the holes into a blind spot (between the double walls, which I can't get access to put a nut in) or put two holes out past the structural inner U-brace and be bolted to only the outer shell, which isn't structural.
tool_scrounge
Southern California
Make a flat metal adapter plate to use the existing toolbox holes and spread the load. Thread the plate so no nut on the far side is required for bolting the casters.
bimmerZ5
that's certainly a possibility. i would think I'd need to use counter sink heads on the screws so they end up flush to the adapter plate and not interfere with the caster plate. i can pre-install counter sink screws downward in the hole pattern of the larger caster plates and use nuts+washer to secure the caster plate to the adapter plate.
The screws will likely be M8x1.25. Do you think counter sink heads at that size would be strong enough? I thought they were weaker than hex heads, but it may not matter...
tool_scrounge
Southern California
Another option is to use socket head cap screws and counterbore the holes so the screw heads to not protrude. Just make sure the adapter plate is thick enough.
bimmerZ5
yeah... before i go doing all this, i'm going to keep looking for a set of casters I can use right out of the box. i don't have the tools to counterbore the holes... and i was thinking 1/8" steel so not sure that leaves enough room for the cap screw head.
