Torque Spec
Charles (in GA)
50 mi south of Atlanta
If you are installing it in a panel or other piece of equipment, the instruction placard in the panel door, or information accompanying the device should have the torque spec.
Charles
W
Charles
Well that is just my luck. It's a used but in very good condition 400 amp disconnect. Of course I thought well I should clean it up a bit. Yup the cleaner took the writing off of the sticker on the door.
pattenp
Virginia - USA
If you can't find the exact specs, 250-275 inch pounds is close to what is needed or 20-22 foot lbs. for 4/0.
Watch this Youtube video about torquing wire.
billsr4
You may want to use a pin connector ,just crimp it on the aluminum and install it in the lug .
it will solve any loose connection issues.
BURNDY HYPLUG AYPO4/0 Made for alum wire to be connected to a mechanical lug.
hh76
NE Wisconsin
You'd still have to torque the lug, wouldn't you?
