water and electric
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
I have all three in my trench from the street. Power, water and phone. Will depend on regulations in your area. Power had to be the deepest with a then plastic cover sheet that said 'Power underneath'. Water and phone went in the trench slightly higher or beside. Mind you that is about 14 years ago now when it was all done.
MustangRick
KC
You need to put some distance between the cable and power. Otherwise, the power can cause signal issues with the cable line. I have never looked it up, but if I were making assumptions, I would put a foot between them.
nehog
Jaffrey, NH
Recognize that when you do run in the same trench, and the water line needs repair, the risk that the cable or power lines may be damaged is greater. In addition to vertical separation I'd suggest some horizontal separation as well...
ddawg16
S. California
Exactly.
If the power is in conduit....not an issue....but if you ever have to work on one of them.....and deeper is better....
If your going to rent a ditch witch....not that big of a deal to just dig 2 trenches...
Falcon67
Merkel, TX
You also risk a 3 Stooges scenario, where you turn on a light and get a flood, or the lights dim when you flush. So protect that power conduit.
nehog
Jaffrey, NH
Brilliant! This is the way to go: run the power wires inside the water pipe, that way the water pipe protects the power lines from accidental damage. Wow, I can't believe I thought of this brilliant idea first. Excuse me while I go file for a patent on this one! :3gears::bounce:
tyjoja
albany ore
I'm a cable dude from oregon, if its your ditch you can do whatever you want. You could twist them together and it wouldn't hurt a thing or cause any problems. common sense is to separate them as much as you can. I would put the power the deepest, as if it ever got dug up it could kill you. then the cable or water, doesn't matter
tyjoja
albany ore
power doesn't have to have a special conduitt/ plastic cover. It's your ditch. I ran 200' ditch from my garage to my shop and I direct buried 3 u/g power wires (for 220v) and water in 3/4" schedule 40 pvc, and direct buried u/g cable wire. If you see a cable guy around the neighborhood stop and tell him what your doing and he will give you the u/g cable wire, the rest buy at home depot.
HOTFR8
If you did that here you would be in trouble. Different rules for different places.
I'm in the process of this right know and have thought hard about one common trench for power and water. I decided against it just because it just did not seem like a smart thing to do. It would have been much easier and less destructive on the lawn and landscaping. I had a back hoe come in and did the water separate at 7' feet deep 400' long. Then had the electrical dug in at 4' and it's 250' long. I put 12'' of sand under the water line and another 12 on the top and then back filled it. The electrical is getting 10-12" of compacted sand on the bottom and another 10-12" on top not compacted then back filled. I'm also running my 4/0 4/0 2/0 6 in 2" PVC. I like to do things once and be done.
Lippyp
Shropshire, UK
I've recently run Gas, Water and Electricity in the same trench, gas is yellow MDPE, water is blue HDPE and electricity is a 16mm2 steel wire armoured cable direct buried. All bedded in sand in about a two foot wide trench, all at the same level with a decent amount of seperation between each. I checked and it meets regs here in the UK, the water and electricity are just supplies to my garage and the gas is the main gas feed from our bulk LPG tank to the house.
NUTTSGT
Northern Central Ohio
Honestly, you should find out if there's requiements where you live. When I trenched (neighbor and myself) for the spouting tile. I caught the old water line for a small barn( I had removed) tied into that and ran the water line in the same trench as the tile. While I had the trench open, I threw in the cable line. I wouldn't have had the electric tossed in the same trench without some type of precaution. . . .a layer of dirt/sand between and the electric in a conduit.
hh76
NE Wisconsin
It's fine. Keep in mind that your water will be below frost line, which I assume would be at least 3-4ft in IL, so you can get some separation between it and the power pretty easily.
You don't have to worry about the water effecting the power, assuming the proper wire is used. Even in conduit, the wire will most likely be sitting in water from the ground, or condensation.
You don't have to worry about the power effecting the water, as the water will be bonded.
As for reparing one or the other, you just have to be carefull. Not really a big deal, it's done all the time.
Edit: Is this a utility feed? Utility companies can differ on what they will allow.
