Harbor Freight Drill Press Purchase
Swiftmotoring
Pinehurst NC
I was in need of a light duty drill press for my garage/shop at home....so I used a coupon to buy a Harbor Freight 5 speed drill press. The support locking handle that secures the table and allows height adjustment will not tighten enough to hold the table in place.....should I return the entire unit because of this or should I simply replace the locking handle with a bolt and nylock? The store is about 50 miles away and with the coupon netted the unit to under $50.....
Thanks
Davefr
OR
Thanks
Either the slit in the column locking collar isn't wide enough or there aren't enough threads on the handle.
I'd fix whichever part is the problem. (with a tap and die set or file) It's probably a 5 minute repair.
Using a bolt/nylock will drive you nuts because table elevation is always being adjusted on a drill press.
A 100 mile roundtrip isn't worth the gas IMHO.
2oolhound
BC Canada
+1
Can you replace the handle with a long bolt that works. just heat it cherry red and bend it to form a handle.
darkk
Willimantic, Ct.
Thanks
I'd return the POS and look for an older used DP on CL.
fitz11
Fox Valley, WI
Try putting the handle in from the other side. I had the same problem with mine and it will only lock with the handle in one side.
Swiftmotoring
Pinehurst NC
Fitz.....you are the winner! I didn't think it mattered which side, the included directions didn't specify. After going onto the HF website and having a look at the directions there....it specified to install the locking pin from the left. Oh well....at least i can say i learned something today! I have less than $50 invested.....I will use it for as long as it will drill holes!
Thanks
